horible responce
horible responce
Ok, I just swapped a b16a into my crx dx, now when i rev the engine i hear the intake take a gulp of air and it serioueley takes about a secound to even begin reving up. Any ideas what that could be?
Re: horible responce (Matrix_Zero)
did you rewire the harness or buy a pre-wired one already? I'd recheck the wires if you did it yourself...Bump for a local
Re: horible responce (rodrez)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rodrez »</TD></TR><TR><TD CLASS="quote">Check the simple stuff first, like your timing. Make sure the timing belt isn't off a tooth. </TD></TR></TABLE>
sounds like timing to me too... when i first installed my b16, the timing was off, and i felt the exact same thing
Also is this condition occuring just during free reving the engine or durring acceleration with the engine under load? I have a 00 b16 and it revs really slow too when there is no load on the engine, drives great though.
If you have a short ram on it, it will make a loud chug sound and then rev. Its because when you flip the throttle from idle to wide open, there is a huge pressure drop in the intake. It takes a split second for the air to get through the filter and make it to the intake manifold so the engine actually has something to "inhale" and burn (rev up).
Modified by realblag at 6:12 PM 7/24/2004
Re: horible responce (realblag)
i have no filter on it currently. I just installed the engine and haven't got one perminently installed. I do have a cone i attach to the intake but it does it weather it is on or off.
luvs2spooge
05-18-2007 05:42 PM
