hood gas spring conversion
Does any body know if the EG hatch spring gas for the rear glass can be used on the hood of a EK?
I looked for gas springs used for rear doors of vans but are too big for the hood.
i would like to do this on my EK...
HT White Ops
Those aren't springs, they're an oil-filled gas shock. Huge difference.
And no, that's not hard. That's actually a kit you're looking at made by Tein. You cannot do it with a carbon fiber or fiberglass hood, they're too brittle and light.
http://www.tein.com/hooddamp.html
HT White Ops
Re: (solbrothers)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by solbrothers »</TD></TR><TR><TD CLASS="quote">so where do you go to buy the little "ball" for the ball joint. i remove those from the decklid of the tC's at work and the "ball" is reused. i have tons of those at work and a set on the hatch of my mustang/</TD></TR></TABLE>
It's a kit. It comes with brackets, ball joints, and shocks. I think NRG makes a knockoff ... that unfortunately costs just as much as the Tein one.
Re: (solbrothers)
its called a heim joint buy a small one, my firend did that, letme guess to help the cf hood stand up straight right? only thing i hate about my cf hood is it straight sags and you can see light through the weave
Re: (solbrothers)
isnt it reassuring that the strongest body part on your front end was replaced with a fiberglasses skeleton and something that you can see sunlight through? nah i love it man saved at least 20 pounds
yes I know there's a specifi kit for it.
but i'm ghetto and would like to try if the EG hatch rear glass stands can hold the weight of my stock hood.
My hood stand just got twisted the other day and there are a lot of surplus from japan sitting around here...
ok i was really eager to do this conversion. And so i was successful!
the hatch dampers were long enough to move the hood all the way up, unlike the tein kit which has limited extension. I can open my hood all the way up, and also 3/4 way up.
I used a pair of eg hatch rear glass dampers, fabricated brackets nd bolted everything on.
spent $18 for this mod... :D
the ball joints at either ends are included in the EG hatch dampers. I just custom fabricated the brackets where the ends bolt right in to.
Re: (srehtorblos)
Password jdm makes a kit also, you can adjust the valves in them so they'll work with cf hoods. Might be worth checking them out if any of you have cf hoods
Hiroshima_VTi-S
17
03-28-2007 01:10 AM
Jamez
Suspension & Brakes
02-12-2005 01:20 PM
