hondata intake manifold gasket- will the d16y8 gasket work on the d16z6
ask the topic says, will the hondata intake manifold gasket for the d16y8 also work on the d16z6?
Down Since Day 1
Re: hondata intake manifold gasket- will the d16y8 gasket work on the d16z6 (tallblondkid)
Im going to guess no since the IM is a little different, but free bump for j00!
someone has to know if they line up the same, thanks in advanced
anybody got some experience with this gasket on either a z6 or y8? I'd like to know how well this thing actually works.
Re: hondata intake manifold gasket- will the d16y8 gasket work on the d16z6 (1 point 6)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1 point 6 »</TD></TR><TR><TD CLASS="quote">Im going to guess no since the IM is a little different, but free bump for j00!</TD></TR></TABLE>
I'm going to guess yes since you can put a Y8 intake mani on a Z6 head. (not the 99-00 intake manifold gasket though, as it has the extra air injection ports).
i know that the IM's r different, but i also know that a y8 manifold can be directly bolted on to the z6 motor
Down Since Day 1
Well it does bolt up, but the runners are a different shape. Only reason why I would think not...
I emailed Hondata a while back asking about the gasket and their reply was that it will work on all d-series motors...this is just what I was told not sure if it's true
Re: hondata intake manifold gasket- will the d16y8 gasket work on the d16z6 (Hondata)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hondata »</TD></TR><TR><TD CLASS="quote">Yes it will work</TD></TR></TABLE>
The only difference between the Z6 and the 96-98 Y8 gasket is the shape of the water port, but they are interchangable and will seal.
A 99-00 Y8 gasket works on any Y8 or Z6 application.
But only a 99-00 gasket will work on a Y8 that is still using air injection.
it wont work. i used a z6 hondata intake manifold on a y8 motor and its leakin like a ****.
Re: hondata intake manifold gasket- will the d16y8 gasket work on the d16z6 (egturbo)
I would think that if it didn't seal properly then you should definately notice at installation. Did you clean all of the old gasket off when installing the new hondata gasket?
Re: hondata intake manifold gasket- will the d16y8 gasket work on the d16z6 (kommon_sense)
yep.. here's the thread i made. https://honda-tech.com/zerothread?id=728044
if u compare the stock gasket there's a lil more gasket up at the top. thats the part thats leakin like a ****
mario_pic
03-29-2008 09:03 AM
eg2phosizzle
02-23-2006 09:02 PM
