Honda Civic 1992-1995 EG Steering Column: horn pads, steering wheel, air bag and more
Old 06-23-2009, 07:24 PM
Master23's Avatar
Default Honda Civic 1992-1995 EG Steering Column: horn pads, steering wheel, air bag and more
To see the original article with images check it out here: Honda Civic Steering Column: horn pads, steering wheel, air bag and more. Garage411.com
A 2-piece safety steering column with slip-joint flange connection is used. The steering column is supported by a column tube and steering lock assembly. All models are equipped with standard driver's side air bag.
Before performing ANY repairs on steering column or column components, Supplemental Restraint System (SRS) MUST be disabled. Accidental air bag deployment could cause serious bodily injury.
DISABLING AND ACTIVATING AIR BAG SYSTEM
Disconnect both battery cables. Remove maintenance lid from bottom rear of steering wheel. Remove Red short connector, located on inside of maintenance lid. Disconnect connector between air bag and cable reel. Connect Red short connector to air bag side of connector.
Activating Air Bag
1. To activate SRS, remove Red short connector from air bag side of connector and reconnect connector between air bag and cable reel.
2. Return Red short connector to storage location on inside of maintenance lid. Install maintenance lid on back of steering wheel.
3. Reconnect battery cables. Check AIR BAG indicator light to ensure system is functioning properly.
REMOVAL AND INSTALLATION
STEERING WHEEL AND HORN PAD REMOVAL AND INSTALLATION
1. Disconnect negative battery cable. Disable air bag system (see top).To remove air bag assembly, remove 2 Torx bolts using a T30 bit.
FYI: Place air bag assembly on workbench. Pad surface MUST face up. If air bag is stored face down, accidental deployment could propel assembly sufficiently to cause serious bodily injury.
2. Remove steering wheel nut. Using slight side-to-side motion, remove steering wheel assembly by pulling outward by hand. To install, reverse removal procedure.
FYI: DO NOT install air bag assembly that is dented, cracked or shows signs of having been dropped.
COMBINATION SWITCH REMOVAL AND INSTALLATION
1. Before proceeding, disable SRS. See top of page. Ensure front wheels are facing straight-ahead.
2. Cable reel is located under steering wheel, in upper steering column. Remove dashboard lower cover and knee bolster. Disconnect cable reel connector from SRS main harness at base of steering column, then remove connector holder.
3. Remove air bag assembly from steering wheel. Disconnect connectors from horn and cruise control switches. Remove steering wheel nut. Mark steering wheel position to shaft and remove steering wheel. Remove upper and lower column covers. Disconnect combination switch connectors. Remove canceling sleeve, cable reel and combination switch.
4. To install, reverse removal procedure. Before installing steering wheel, center cable reel by rotating clockwise until it stops and then counterclockwise approximately 2 turns. Arrow mark should face up and Yellow gear tooth should be aligned with mark.
IGNITION SWITCH
FYI: Before performing ANY repairs on steering column or column components, Supplemental Restraint System (SRS) MUST be disabled. Accidental air bag deployment could cause serious bodily injury.
Removal
Remove steering wheel and horn pad. Remove steering column covers. Remove steering column holder flange bolts and lower steering column. Disconnect ignition switch. Center punch 2 shear bolts and carefully drill heads off lock shear bolts. Remove bolts and switch.
Installation
1. Install ignition switch. Use NEW shear bolts and tighten loosely. Ensure pin on ignition switch is aligned with hole in steering column.
2. Insert key and check for proper operation of ignition switch. If switch operates properly, tighten shear bolts until heads break off. To complete installation, reverse removal procedure.
STEERING COLUMN
Removal
1. Remove steering wheel and horn pad. Remove combination switch and set aside on vehicle floor. DO NOT disconnect combination switch connector. Disconnect remaining wire connectors from left side fuse box, under dash.
2. Remove steering joint cover. Center tilt lock assembly. See figure. Remove steering joint bolts. Slide steering joint upward on column. Align steering joint upper bolt hole with groove around column. Loosely install upper bolt.
3. Loosen, but DO NOT REMOVE, column holder flange bolts. See figure. Remove upper and lower column covers. Remove holder flange bolts. Remove steering column assembly.
Installation
1. Guide steering shaft through firewall. Align bolt hole in steering joint with slot in steering gear pinion shaft. Install steering joint on pinion shaft. Loosely install steering joint bolt. Install steering column and column holder flange bolts. Tighten bolts to specification.
2. Connect ignition switch connector. Install steering joint cover. Install combination switch, canceling sleeve and circlip. Install cable reel assembly, taking care to align slot in canceling sleeve with projection on cable reel.
3. Install SRS wire harness on underside of column bracket with clip. Install upper and lower column covers. Install driver's side knee bolster and dashboard lower cover. Install steering wheel and air bag assembly.
Steering column overhaul is not recommended by manufacturer. If worn or damaged, replace steering column as an assembly.
TORQUE SPECIFICATIONS Ft. Lbs. (N.m)
  • Lower Column Holder Flange Bolts: 29 (39)
  • Lower Steering Joint Bolts: 16 (22)
  • Steering Wheel Nut: 37 (50)
  • Tilt Lock Bolt: 15 (20)
TORQUE SPECIFICATIONS INCH Lbs. (N.m)
  • Air Bag Assembly Torx Bolts: 89 (10)
  • Tilt Lock Nut (Left-Hand Thread): 89 (10)
  • Tilt Lock Plate Bolt: 89 (10)
buffdaddy357
10-25-2008 06:41 PM
Civic-Kids
04-13-2007 07:42 PM
civicVI
11
06-23-2006 12:33 PM
ProjectLudeSiR
08-22-2005 08:17 AM
KingJeff
08-23-2004 02:28 PM
Quick Reply: Honda Civic 1992-1995 EG Steering Column: horn pads, steering wheel, air bag and more
