HELPPPP rhd conversion in eg6 left turn does not work
stuff is working except for the left turn signal. the hazrds work on both sides in the rear but will not blink in the left front.
then turn on the left blinker and it will not blink. it will not blink on the dash or on the cluster as well. but the front one does. so if you have any in put please help me..
Re: HELPPPP rhd conversion in eg6 left turn does not work
using jdm wiring all around and then the usd harness in the rear. that has been repinned. and the combo switch is jdm. fuses and relays are all good
you sure the jdm combo switch has the same pin out as the usd one? I used all usdm wiring in my rhd civic along with the usdm combo switch and everything worked out just fine. Has it ever worked normal before?
got it figured out when i got the conversion from steve at hmotors the cut all the wiring off for the lights and they cut it so far back that the wires pulled back in the loom. and the left front turn signal for the marker light was cut by the boot. which interupts the circut. once i re conected that wire all was good. just took 2 days to figure out. gave steve a call and told him so he could prevent anyone else from having the problem.
