HELP! Weird idle problem..
First off, i did search, and none of the problems seemed to match mine.
Today when i was driving, my car started to idle at like 200 rpms. Its the last bar before the bottom of the tach. It feels almost as if my car is about to stall. I have no idea what could have caused this, cause it only does it every once in a while. Its probably nothing serious but ide rather catch it now before it does become something serious. Any input will help, thanks.
Re: HELP! Weird idle problem.. (v0lcom27)
hmm...check to see if your throttle body gasket is still good...if not than it could be your IAC...my bro has the same stituation...
Unceasing Measure
Re: HELP! Weird idle problem.. (93_cxEG)
Time for a tune up. Replace your fuel filter, dizzy cap and rotor, plugs, run some fuel system cleaner and maybe even run a bit of seafoam through the bitch. It's probably some gayass blockage somewhere from fuel or gunk deposits and a nice tune up will probably fix it in a jiffy.
civikhatch91
09-07-2008 07:50 AM
White LX
10-15-2001 12:53 PM
