help with swap
help with swap
im swapping a 99 gsr swap into my 96 hatch, but the motor came out of a 93 del sol, which is obd1, what my question is what am i going to need to convert over from the parts that are on the motor from the del sol?
also what mount do I use for the tranny?
im stuck please help!
Re: help with swap (greenh22eg)
youw ill need to change the distributor, injectors, and alternator and put a 96-99 gsr wire harness...you could wire up that stuff yourself if you know how to....about that tranny mount idk ive never done a swap into a ek
Re: help with swap (JayDeMgsr)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JayDeMgsr »</TD></TR><TR><TD CLASS="quote">youw ill need to change the distributor, injectors, and alternator and put a 96-99 gsr wire harness...you could wire up that stuff yourself if you know how to....about that tranny mount idk ive never done a swap into a ek</TD></TR></TABLE>
wrong
He doesnt need to change over any of those things. He simply needs to reuse his civic harness and adapt it to the motor. 96-99 GRS harness is a 2 piece harness while his civic harness is one piece. They are not compatible.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SiRek4 »</TD></TR><TR><TD CLASS="quote">actually all youll need is mounts, you can use the 99-2000 si mounts.
as far as the wire harness goes, just get a jumper to convert it.
no more no less!!!</TD></TR></TABLE>
wrong
He needs the rear tranny mount form the SI and the driver side mounting bracket, but he ALSO needs shift linkage from a '94-up integra or '99-'00 SI. The delsol linkage is different.
He DOES need a jumper harness if he plans to use the obd1 ecu, but he needs to reuse his civic harness.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by greenh22eg »</TD></TR><TR><TD CLASS="quote">
Reuse your stock civic upper tranny mount.
wrong
wrong
Itzmy91Teg
05-04-2007 08:32 PM
EK SQUAD 425
03-24-2006 06:45 PM
