HELP with suspension please?
Hi.
I have a real JDM 93 Honda Civic Eg6 my current suspension setup is:
00 itr 32mm 5 lug
Silkroad Section rma8 coilovers
Skunk2 pro series Front & Rear camber kit
Polished asr sub brace
Function7 itr lca's with spherical bearings
My question is, I want to get the Tein Flex coilovers, but the dude I'm trying 2 buy them from has the jdm itr 5 lug 36mm conversion. Will they fit OK, NO PROBLEMS?
Yes I know this could be a dumb question, but I'm not about to spend $750 on something I'm not sure of, Can anyone help me?
00 itr 32mm 5 lug
Re: HELP with suspension please?
Responding from your PM.
I don't see any logical reason that the 32mm and 36mm set up's wouldn't allow to run the same suspension... The only difference between the 2 would be the size of axle which has no correlation to the coilover itself.
In actualitie the axles themselves are pretty similar minus the fact of the mm difference...
I don't know 100% but i quite the knowledgeable one, and i would trust my info unless anyone else can offer REASONABLE LOGIC of why i wouldn't be correct...
I'm 99.9% sure they'll fit your car. One good way to find out is to shop around for coilovers and see if the part numbers are different for JDM and USDM Type-Rs, but there probably isn't any USDM or JDM designation on them.
treeafodo
11-19-2013 03:22 AM
