HELP!!!! Steering wheel Shakes when I go over 70mph
Old 12-21-2005, 05:56 AM
lcjarrett's Avatar
Default HELP!!!! Steering wheel Shakes when I go over 70mph
When I am on the freeway and I go over 70mph my steering wheel starts shaking...What is the problem? Please Help me out.
Old 12-21-2005, 06:24 AM
Solracer's Avatar
Default Re: HELP!!!! Steering wheel Shakes when I go over 70mph (lcjarrett)
Your Tires are probaly out of balance.
Old 12-21-2005, 06:28 AM
IHateJDM's Avatar
Default Re: HELP!!!! Steering wheel Shakes when I go over 70mph (Solracer)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Solracer &raquo;</TD></TR><TR><TD CLASS="quote">Your Tires are probaly out of balance.</TD></TR></TABLE>
that or axle.
pumatec8's Avatar
car shake=balance...
Old 12-21-2005, 07:16 AM
lulz
92BluEH-3's Avatar
Default Re: HELP!!!! Steering wheel Shakes when I go over 70mph (pumatec8)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pumatec8 &raquo;</TD></TR><TR><TD CLASS="quote">car shake=balance... </TD></TR></TABLE>
balance always get tires balanced.
Old 12-21-2005, 07:28 AM
dthug's Avatar
Default Re: HELP!!!! Steering wheel Shakes when I go over 70mph (92'BluV-tecHatch)
gets your wheels aligned
Old 12-21-2005, 07:44 AM
amckee's Avatar
Default Re: HELP!!!! Steering wheel Shakes when I go over 70mph (dthug)
Alignment has nothing to do with shaking or vibration.
Get your tires balanced.
Old 12-21-2005, 07:46 AM
JDM_teh_WIN!!'s Avatar
"Get your tires balanced" is not the correct answer. That's a place to start. It could be a number of things. If you can't figure out what it is, take it to an experienced person who can. You'll end up getting raped by a Honda dealer, since they will most likely start with a tire balance, if that is not the problem they will move on to the next thing until they figure out what's wrong. They will also charge you for all the unnessessary time it took them to figure it out. If you get lucky and get a good tech it won't be so bad. Good luck.
PS. This should prolly be at the top but....Can you give more info on how and when it started. Just out of the blue or what???
Old 12-21-2005, 07:49 AM
amckee's Avatar
Default Re: HELP!!!! Steering wheel Shakes when I go over 70mph (JDM_teh_WIN!!)
Maybe you would like to list the "number of things" for us?
Old 12-21-2005, 07:52 AM
IHateJDM's Avatar
Default Re: HELP!!!! Steering wheel Shakes when I go over 70mph (amckee)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by amckee &raquo;</TD></TR><TR><TD CLASS="quote">Maybe you would like to list the "number of things" for us?</TD></TR></TABLE>
If he knew, he wouldn't have mentioned a dealership.
I would start with unbalanced tires, then make sure lugs are tight, then look for bubbles in the tires (hit any bad potholes lately), then bad cv joint in axle.
Feel free to add anything I missed.
Wheel balance
Bent Rim
Alignment
Worn Bushings
Wheel Bearing
Inner CV joint
Bent/Cracked axle
Various annomolies
Old 12-21-2005, 08:01 AM
amckee's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDM_teh_WIN!! &raquo;</TD></TR><TR><TD CLASS="quote">Wheel balance
Bent Rim
Alignment
Worn Bushings
Wheel Bearing
Inner CV joint
Bent/Cracked axle
Various annomolies</TD></TR></TABLE>I think the guy would know if he smacked something hard enough to bend an axle or rim #1 and #2 those problems would show up at all speeds not just over 70. Alignment absolutely will not cause a shake. Wheel bearings roar and grind but will not cause the "it only shakes when I go above 70 phenomena" . Inner CV joint? What bushings??
Modified by amckee at 9:13 AM 12/21/2005
Old 12-21-2005, 08:11 AM
JimmyAtlantis's Avatar
The best and cheapest place to start is to have at least your front WHEELS balanced. And when they are balancing them they will also be able to tell if they're bent.
Old 12-21-2005, 08:42 AM
civic_tuned's Avatar
listen to the guy. what happens when u dont have a alignment u will have premature tire wear which will cause yur car to shake so it might cause problems think about it.
Old 12-21-2005, 08:49 AM
Default Re: HELP!!!! Steering wheel Shakes when I go over 70mph (civic_type_r)
Ball joints
Control Arm Bushings
Stripped Tie Rods
Old 12-21-2005, 09:17 AM
BIRDISTHEWORD's Avatar
You need your tires balanced and check the rotation of the tire. If the rotation is wrong that will also cause it to do that.
Old 12-21-2005, 09:44 AM
lcjarrett's Avatar
i wanna say thank you to everyone for given me advance...
Old 12-21-2005, 10:37 AM
old man neri's Avatar
Default Re: (lcjarrett)
I just want to add one thing that is not directed at the original poster.
If you are driving in winter conditions and are experiancing this; a very common thing to happen is ice or snow will build up on the inside of the rim in one small spot (usually after parking or having an e-brake contest) it will throw the balance off. So if you have this problem don't go right away to a wheel and tire shop just try chipping the ice off with a flat head.
Cheers!
Old 12-21-2005, 11:50 AM
krisjk2's Avatar
Default Re: (old man neri)
not trying to thread jack but a similar issue..
when i brake lightly at high speeds my steering wheel shakes a bit. is that normal or is it a warped rotor or something?
Old 12-21-2005, 11:53 AM
IHateJDM's Avatar
Default Re: (Muttly)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Muttly &raquo;</TD></TR><TR><TD CLASS="quote">when i brake lightly at high speeds my steering wheel shakes a bit. is that normal or is it a warped rotor or something?</TD></TR></TABLE>
if it shakes only when braking, its warped rotors.
dthug's Avatar
or how about your not supposed to be driving over 70mph anyways
Old 12-21-2005, 07:24 PM
lcjarrett's Avatar
I was in the fast lane
Old 12-21-2005, 09:25 PM
Mr. Wonderful's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDM_teh_WIN!! &raquo;</TD></TR><TR><TD CLASS="quote">"Get your tires balanced" is not the correct answer. That's a place to start. It could be a number of things. If you can't figure out what it is, take it to an experienced person who can. You'll end up getting raped by a Honda dealer, since they will most likely start with a tire balance, if that is not the problem they will move on to the next thing until they figure out what's wrong. They will also charge you for all the unnessessary time it took them to figure it out. If you get lucky and get a good tech it won't be so bad. Good luck.
PS. This should prolly be at the top but....Can you give more info on how and when it started. Just out of the blue or what???</TD></TR></TABLE>
this guy is right. my car did this on three separate occasions and neither time was it a balancing issue. the first time it was the axles, the second time it was the mid-shaft, the third time it was toe.
civicb16eg
05-15-2006 10:33 PM
Circuit Star-29
11-15-2004 11:15 PM
ITRIDER2001
09-21-2004 04:37 PM
FULL-RACE EP3
08-05-2004 02:34 PM
Cryptopsy
16
06-26-2003 01:47 PM
Quick Reply: HELP!!!! Steering wheel Shakes when I go over 70mph
