Help with SRS light and check engine
Old 12-25-2007, 08:52 AM
elmejor's Avatar
Default Help with SRS light and check engine
My 95 honda civic SRS light in dashboard is flashing on and off, and after that my check engine light starts flashing 9 times and then stops and continues like that, im scared of what could it be?
Old 12-25-2007, 09:05 AM
z6hatchboy's Avatar
Look in the first few threads of this forum, how to check cels (check engine light) i think. That'll tell you what it is, come back and we'll tell you how to fix it.
Old 12-25-2007, 09:15 AM
elmejor's Avatar
Default Re: (z6hatchboy)
in the CEL thread it says to have the car off and also to cover the 2 pin plug with a connector i didnt do that, my car was on and it suddently started doing and now it does it all the time. BTW going by the thread then it would be code #9 which is cylinder sensor
Old 12-25-2007, 09:19 AM
z6hatchboy's Avatar
Are you sure you counted them right, b/c of the long + short blinks? If so, im not familiar with the cylinder sensor. Try using the search button and searching it, and im sure others chime in and help you out.
Old 12-25-2007, 10:02 AM
elmejor's Avatar
i think that it might be the valve because my uncle told me that they are making a weird noise, and making the car very lazy
Old 12-25-2007, 11:32 AM
z6hatchboy's Avatar
Default Re: (elmejor)
May need to adjust valve lash for that.
G. Man
12
02-25-2011 06:13 PM
butter99
15
12-18-2008 04:27 PM
SlammedBlackGSR
11-20-2006 02:04 PM
boosted96midorihatch
05-14-2006 09:03 AM
sergei_sh
03-13-2006 06:19 PM
Quick Reply: Help with SRS light and check engine
