HELP! Setting Blackworks Coilover
Re: HELP! Setting Blackworks Coilover
You needed to set height before you installed the coil overs.
You’re gonna have to unbolt the strut fork, loosen the bottom ring, and spin the bottom of the coil over until you see it move more up towards the threads.
Hello, thank you for your answer, I have already settled this part I went up the lower part to the highest towards the spring
O.G. triple O.G.
because...Blackworks
Blackworks is overpriced Ebay brand...just like Function+Form, Yonaka, Godspeed, EMUSA, blah, blah blah...
yes I have two I already change the tension of the spring before it was even higher as if I was original! someone told me that they may be models for EK or Integra?
O.G. triple O.G.
IT'S NOT THAT DIFFICULT.
-Intl Steve Krew
You've bottomed out on the tube.
In order to go lower, droop the spring by lowering the preload collars but be aware that you will wear the strut faster and blow it out if you go too low.
Have fun ruining your car and spine. I don't miss the days of trying to get as low as possible
-Intl Steve Krew
compared to the tension of the spring? I can not go down anymore! it will not be in tension, I do not ask a question for the back I may be so low that I can put the car on the ground, there has not been a reversal of shock absorbers, not springs
Fish Twig
I see a good decent amount of thread to still lower the spring, One92Eg6 has an image and explains what I'm saying. But if he can't lower it any more, and that is the max it can lower than there is nothing you can do other than cut the spring which can be dangerous. SIMPLE.
-Intl Steve Krew
But yes, if he droops the spring itself, he can lower the vehicle more.
-Intl Steve Krew
The last thing you can do is remove the locking collar for the Spring collars, and lock the spring collar to the height body collar. That is the absolute maximum you can go, safely.
Fish Twig
the heck you need to drop the strut down more for, silly lowering attention.. go find a coilover with short strut body. All thats going to do is make the ride even more stiff.
I would like to be able to go down to the level of the wing board, if I go down the wheel spring it will float, at the back I have no problem, sorry for the translation
