HELP! Radiator Issue (I Think)
I have an issue and i need an expert's opinion on what the problem is. I was driving my civic on the freeway and suddenly it overheated. I parked the car and there was heat coming from the bottom of the intake manifold and fuel rail. I look at the back and on the frame of the car, there was coolant all over, almost as if a hose pop. So they check it out at wheel works and they said i needed a new radiator, upper/lower hoses and thermostat. I don't understand why i need those thing if all that is at the side of the engine when the issue was located at the back of the engine.
PS: I had a coolant leek a week before.
Re: (bmorei9s08)
Ok, so i took the car to teh shop, and it was one of the hoses that had popped behind the block. So i was driving today for about 20 min and my car started to heat up. Could it be that the fan doesn't work anymore? Oh, and i filled it up with coolant the other day so i'm not low on that
Re: (benji7288)
Alright, so i checked the fan n it only turns on while the A/C is on. The weird thing about it is that the engines sounds weak. I've never herd the engine sound like that w/ the A/C on. Also, check if there was any bubbles inside the radiator and it seems to be fine.
ED6
01-18-2004 06:44 PM
