help on pwr window conversion for 95 cx hatch
Re: help on pwr window conversion for 95 cx hatch (rayzhatch95)
you need the power window regulators (scissor looking things) from any 92-95 Civic coupe EX and the door harnesses from that car as well. you'll probably want to get the door panels and power window switches as well from the same car. then you can either get the door harness wired up ghetto with switched 12v + ground, or you can get the complete main harness (dash harness) from the power windows equipped Civic and swap yours out for that one, then the door harnesses will have a place to plug into since the new main harness has connectors that come out the sides of the dash.
i did this conversion in my 99 cx. i got all my parts from a wrecked 99 Si. worked great. i got power locks, power mirrors, keyless, (and i could've done cruise too) all at the same time.
Re: help on pwr window conversion for 95 cx hatch (YumGTR)
thanks i got everything but the harness that came from the dash i was at my buddys junk yard and there was a wrecked 4 door with no doors the main harness was cut but i got the ends (cut them so i could have the pins) that come out of the door jams i thought i could maybey run som wires myself to pwer them up
Hi, i don't know if this will help, but here's a link to a website that shows the installation steps. It was on H-T a while back. Hopes that helps.
http://repo.jackmoves.com/view...bun42
dustin
dustin
DAPhatch99
11
04-04-2014 05:54 PM
junintegra2000
07-11-2008 05:23 PM
SovXietday
07-23-2007 06:05 PM
Stitch01
04-08-2006 02:06 PM
