Help with a possible clutch problem
When i went to start my car today, i went to push the clutch in and the pedal went straight to the floor. I struggled to get it into any gear, it finally went after a lot of effort. I wasnt able to get it into reverse though. Have any ideas on what the problem could be?
Seagull Management
You wont see it on the engine side. You'll have to get under the dash and take a look. Also pull back the boot on the slave cylinder on the transmission and see if its leaking, and check the hard lines and flex hose for leaks.
Turbo D17
10-20-2004 03:28 PM
