help!!! p0170 p0172
help!!! p0170 p0172
d16y7. compression @ 130 all cylinders fuel pressure 34psi 42psi without hose. did valve adjustments new upper denso sensor. new cap rotor plugs wires. checked return line the only thing I ha end done are the injectors. swapped them with some other used ones and same results. what could it be
Hondatypr636
08-22-2011 11:19 AM
