HELP!! OEM CTR 22mm rear sway bar END-LINKS missing
Hey what's up
I just bought some OMNI rear lower control arms, ASR rear subframe brace & new OEM CTR 22mm rear sway bar for my 00 civic hatchback from passwordJDM. Well it doesn't come with endlinks for the rear sway bar so where can I get some?
OEM CTR or aftermarket?
Can I use 99 civic SI endlinks?
Thank you
Thank you
Re: HELP!! OEM CTR 22mm rear sway bar END-LINKS missing (RhdRicheeee)
you need 99-00 Si endlinks or what I'm using, Aurora spherical bearings
this is the best deal on brand new endlinks I'v ever seen, wish I would have gotten these
http://www.jhpusa.com/catalog/...=1431
If you get brand new endlinks from honda expect to pay $40+ EACH, and you need the nuts that go with it
Re: HELP!! OEM CTR 22mm rear sway bar END-LINKS missing (sicones)
You can also get them from Honda. When I put my swaybar on thats where I went to get them. Surprisingly they werent tooo expensive.
Re: HELP!! OEM CTR 22mm rear sway bar END-LINKS missing (jdmztrane)
function7 also has some that would work and they are very reasonable ($45). I'm grabbing these to use on an ITR rear sway instead of OEM Si endlinks. Quality looks pretty darn good too.
http://store.function-7.com/ca...40a82
Here's an email reply from function7 regarding their endlinks:
"It comes with a standard set of hardware (bolts/nuts/spacer
nuits/locknuts/washers) that allow it to be used with different sway
bars.
If you use the OEM endlinks, you'll find that the top end is too short
to fit through the rubber bushing on the ITR sway bar.
Thanks
Adrian Teo
Function7 Engineering"
bars.
Thanks
Adrian Teo
fake mugen power
12-19-2003 01:04 AM
Joyride MotorArt
10-13-2003 07:21 AM
