HELP:which manual transmission fluid to get for type r trans
Re: HELP:which manual transmission fluid to get for type r trans (97VtecIN)
syncromesh is for tranny's with worn syncros. it has a metal compound to aid the synro's with added friction. if you use it with no need it can cause a serious build up causing a gumming effect which results in very high tranny temps due to friction. for the type r trannys you should use 10w 30 full synthetic. i personal prefer royal purple, red line, mobil, or castrole.
SlowDriver74
05-28-2012 02:52 PM
TWSS-EF9
14
05-31-2011 12:58 PM
