Help! Lowered Car, Ticking noises in the back!
as the topic says: after i lowered my car 1.5 in the front and 1 in the back, its been making "ticking" noises in the rear. Has something to do with the "CV Boot"? thats what someoen told me. What should i do to fix this problem? cost? time? whatever you can give me will be mucho gracias
Re: Help! Lowered Car, Ticking noises in the back! (RockLee`)
try searching before you post a topic next time:
https://honda-tech.com/zero...age=1
(I apologize if search is down)
Re: Help! Lowered Car, Ticking noises in the back! (96BlackHB)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 96BlackHB »</TD></TR><TR><TD CLASS="quote">try searching before you post a topic next time:
(I apologize if search is down)</TD></TR></TABLE>
thanks, now mods please lock this thread.
Re: (imonx850)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by imonx850 »</TD></TR><TR><TD CLASS="quote">Your Rice, you Eat Rice!! GRRR...
^_^</TD></TR></TABLE>
okay.... anyways dont lock this, cause the link you gave me talked about Trailing arm bushing. that might be it but anyone else know?
Re: (RockLee`)
cv boots are part of your axles, at each front corner. you don't have any cv boots in the rear, unless you have awd or rwd. by the way, is the noise coming from rear inside the car, or outside?
Re: (96BlackHB)
you probably didnt properly seat the spring when you installed it. the sound is probably the spring shifting. could also be the springs hitting each other O_o
details man!
details man!
Re: (yayabtech)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by yayabtech »</TD></TR><TR><TD CLASS="quote">you probably didnt properly seat the spring when you installed it. the sound is probably the spring shifting. could also be the springs hitting each other O_o
details man!</TD></TR></TABLE>
correct! its in the back, the noise seems from the outside. if this ticking noise keeps happening, will my car exploded? well something jsut as bad?
Re: (RockLee`)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RockLee` »</TD></TR><TR><TD CLASS="quote">
correct! its in the back, the noise seems from the outside. if this ticking noise keeps happening, will my car exploded? well something jsut as bad?</TD></TR></TABLE>
Gotta give more info, maybe you dropped a screw in your hub cap. There is mad talent here! you will get answers but ya gotta help us help you!
Re: (RockLee`)
no your car will not exploded!
Check your brakes, i once had a noise coming from my rear brakes in my sentra and low and behold i had a rock stuck in there, go figure.
But it seems as though your springs arent seated right
Lamchop0000
08-06-2003 10:24 AM
