help installing headers
Guest
Posts: n/a
Re: help installing headers (SIRIUS)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SIRIUS »</TD></TR><TR><TD CLASS="quote">Post up pics of the V6 or V8 swap you have in your hatch This must be bad-***!</TD></TR></TABLE>
LOL
yeah dude, i think you bought too many... you only need one header
LOL
Re: help installing headers (poppycock)
Remove heat shields
Un-bolt stock manifold from cat (or b-pipe if applicable)
Un-bolt stock manifold from head
Remove stock manifold
Install new header in place
Bolt to head
Bolt to cat (or b-pipe/test pipe if applicable)
Don't forget to replace both gaskets and use plenty of penetrating lube. It's really easy.
P.S. I hope you only bought one header.
Bolt to head
Re: help installing headers (Mr Milano)
i only bought one....damn smart a$$es...lol.... dc 4-2-1...and since there are 4 pipes....i say it as more then one...i know a lil more than that....
Electrician
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by poppycock »</TD></TR><TR><TD CLASS="quote">i only bought one....damn smart a$$es...lol.... dc 4-2-1...and since there are 4 pipes....i say it as more then one...i know a lil more than that....</TD></TR></TABLE>
How many actual pipes are welded to the flange has NOTHING to do with the proper term for it. Even if I had 150 pipes welded to one flange, it's still a HEADER. If there is multiple flanges for multiple exhaust manifolds (2 cylinder heads, etc), then it's HEADERS.
BTW, it's a bolt-on. Un-bolt, bolt it, go vroom vroom.
1 Post
Re: help installing headers (Dimi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mr Milano »</TD></TR><TR><TD CLASS="quote">Remove heat shields
Bolt to head
P.S. I hope you only bought one header. </TD></TR></TABLE>
is penetrating lube like PB blaster?
Bolt to head
Re: (swatdog)
Here(if you still need help that is) : https://honda-tech.com/zerothread?id=659624
But sadly my pics are down..... ill switch servers.
Re: help installing headers (thrty8street)
It's an aerosal spary usually but with more of a "stream" tip then a "spary". WD-40 I guess would be the most recognizable, but it's not very good in the automotive world. WD40 is more of an all around lubricant, not very potent at desolving rust but works mostly for around the house type stuff. Go to any automotive store and buy a case. Most of the good stuff you have to order, but useally the stuff you find at most automotive stores works 90% of the time.
Wurth stuff works pretty good for me.
1 Post
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by thrty8street »</TD></TR><TR><TD CLASS="quote">
is penetrating lube like PB blaster?</TD></TR></TABLE>
PB Blaster or Liquid Wrench.
