Help Im pissed right now!
OK, you know the punch pin in the shift rod... My friends always removed it for me. I am taking off the tranny right now by myself and I got the stupid punch stuck in the pin from the top I cant seem to get it out. Is there some secret to getting that stupid pin out and can I do it from the bottom..? Please help!
Re: Help Im pissed right now! (slowd16z6)
yep, get a sledge hammer and keep hiting the punch..it will eventually come out...just be a man about it and suck it up lieutenant!!!
I cut my finger... and not much room to really slam at it with anything... Ill get this bitch but if anyone has some other suggestions....
ok I got un stuck from the pin on the top... who the know the best way to attack this pin from the top or bottom? and what size punch should I use?
I use a socket. You know, one of those 1/4" drive long shank 6mm ones that you never use.
Fine a socket that is slightly smaller then the bitch pin. Stick a nail in the socket that you can stick into the center of the pin. that will help keep it centered while you bang the living **** out of it.
Oh, and put an appropriate extension on the socket.
It also helps to lift the car as high as you can to give yourself more room to work.
And please put 2 jackstands, 2 wheel chocks, and leave the jack extended under the front of the car for extra safety, especially if you are by yourself.
damn, I can't even nut that fast.
SJR
25
05-19-2005 04:27 AM
gocivicgo
13
06-26-2003 05:36 AM
