HELP!!! Clutch Problem
Hi All,
Got in my car this afternoon to leave work and my
clutch pedal sank to the floor. It only came back up about 2 Inches.
The car is driveable but I have to press the clutch pedal to the floor.
I immediately went and got DOT3 fluid and put it in the resovoir dry as a button
must of been a great guess that i had but after driving for awhile about 1hr. Pedal
still does the same thing...
Anyone have any ideas how to fix???
Also SRS popped light popped on 2 days before any easy way to reset
I heard blue connecter near the fuse box... Is that correct???
Thanks in advance!!!!!!!!!!!
Re: HELP!!! Clutch Problem (fasterthenmost)
check your clutch slave cylinder (found in front of transmission case), see if the nut is loose...yours sound like a leaking problem. if possible re-bleed the entire thing.
thanks for the super fast reply imma gonna go outside and check now if the nut is there or loose ... How do i re-bleed??
my brother wants me to check his PM's ...
don't know how on this board... ( probably dumb question but checked in the profile )
Please don't flame this is not my username
look under your dash and look at the top of the clutch pedal and see if the clutch master cylinder is leaking. most likely is.
Re: (fasterthenmost)
To check your PMs, go to My Profile. On the right hand column there is a link to "Instant message history". Click there.
Re: (Kapolei INTEGRA)
oh yes, that right master cylinder could also be the culprit. haha...why didnt i think of that. if you see it wet down there go get the master cylinder replaced
ok i am going outside to check for the leaking above the pedal gonnda need someone to help me bleed ... got you PM just fine now!!!!
Anyone have any ideas on the SRS light???
