Help Breaking up problem
i have a 92 hatch and swapped the stock blown motor for another stock motor... the motor will start and idle fine. but when you accelerate the car falls on its face. i tested the tps, changed the fuel filter, changed the fuel pump, the distributor, checked the timing, and put new spark plugs...anyone have any idea what it could be...otherwise i'm gonna rip this motor out and throw an ls in it. Thanks
Re: (JDMlyfestyle)
well actually dx...but it does it when its sitting also it doesn't have to be moving...it sounds like its not getting enough fuel but smeels like its running rich.
Re: (JDMlyfestyle)
yup did a compression test...came out good according the what the manual wants for compression.....it idles good put then when u hit about 2000-2500 rpm it just falls on its face...
Re: Help Breaking up problem (reef188@aol.com)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by reef188@aol.com »</TD></TR><TR><TD CLASS="quote">otherwise i'm gonna rip this motor out and throw an ls in it. Thanks</TD></TR></TABLE> PROBLEM SOLVED
civichatch201
09-30-2009 07:12 PM
boostedtsi
10-26-2008 09:01 PM
One Bad GeeSeeR
08-10-2002 08:01 PM
