HELP!! Blox intake Manifold install
Old 05-08-2008, 04:26 PM
djviet2000's Avatar
Default HELP!! Blox intake Manifold install
that nipple right under the main coolant line that connects to the radiator. where does that little nipple go to?
Old 05-08-2008, 05:13 PM
sicones's Avatar
Default Re: HELP!! Blox intake Manifold install (djviet2000)
heater core, if you look there is a little arrow pointing to a hose
Old 05-08-2008, 05:24 PM
mikeycivic's Avatar
Default Re: HELP!! Blox intake Manifold install (sicones)
if you are talking about the nipple that you are pointing to? It goes to the throttle body, not the heater core.
Old 05-08-2008, 05:43 PM
turbo-2nr's Avatar
Default Re: HELP!! Blox intake Manifold install (mikeycivic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mikeycivic &raquo;</TD></TR><TR><TD CLASS="quote">if you are talking about the nipple that you are pointing to? It goes to the throttle body, not the heater core.</TD></TR></TABLE>
X2
Old 05-08-2008, 10:13 PM
djviet2000's Avatar
Default Re: HELP!! Blox intake Manifold install (turbo-2nr)
the one with the red mark. that goes to the throttle body? the guy who installed my manifold saying that is the only nipple he doesnt know where it goes. he put a cap over it and tighten it down and coolant is dripping out. is that safe?
Modified by djviet2000 at 12:29 AM 5/9/2008
Old 05-08-2008, 10:49 PM
djviet2000's Avatar
Bump
Old 05-08-2008, 10:51 PM
jord18's Avatar
yaa it goes to the nipple thats under the throttle body which then goes into the iacv
Old 05-08-2008, 11:40 PM
djviet2000's Avatar
Default Re: HELP!! Blox intake Manifold install (jord18)
there is coolant spitting out of it? coolant runs thru the throttle body?
Old 05-09-2008, 04:09 AM
mikeycivic's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by djviet2000 &raquo;</TD></TR><TR><TD CLASS="quote">there is coolant spitting out of it? coolant runs thru the throttle body?</TD></TR></TABLE>
yes dude. It stops the throttle from sticking on cold starts. Your question has been answered. If you look at the diagram you can see exactly where it goes. TO THE THROTTLE BODY
Old 05-09-2008, 05:01 AM
pilot03's Avatar
Goes to the throttle body.
Old 05-09-2008, 06:28 AM
Man U FTW
Schister66's Avatar
yes dude. It stops the throttle from sticking on cold starts. Your question has been answered. If you look at the diagram you can see exactly where it goes. TO THE THROTTLE BODY</TD></TR></TABLE>
It seems your question has been answered if you took the time to read
marshall12395
05-15-2014 08:17 AM
g_steelo99
08-05-2012 07:23 PM
chadmasterc
03-01-2006 07:06 PM
TyeJ23
08-31-2005 07:52 PM
Quick Reply: HELP!! Blox intake Manifold install
