HELP! B&M fuel gauge install at the rail?
Can I install my gauge at the rail using the hardware that comes with the kit only? And what is the fuel pressure supposed to be on a STOCK B16a like in a Civic Si? thanks!
Re: HELP! B&M fuel gauge install at the rail? (Kermit EK)
hows it going the first thing u should do is to install the gage it goes on the canister thats on the left side of the fire wall not the evap right above that one after u install the gage turn the key to the on position without turning the motor on this will tell you the stock fuel pressure i belive is 25psi if u go under you will lean out try not to do this because u will detonate not good remember its allways better to run rich that lean, and do not exede 50psi i dont think you injectors will take it,and if your ignition is not upgraded you will just be wasting gas cause you wont have enough spark to burn the higher volume of gas. good luck let me know how it goes
vietdragontekx
02-12-2006 06:22 AM
