help..
Old Jan 25, 2004 | 12:37 PM
cegleitz's Avatar
Default help..
just got my whole exhaust system redone. New headers, cat, and cat-back greddy exhaust. Well i had to have an o2 sensor bung welded to the exhaust. Got that done, came back home and put it all one. I had to extend the wires on the o2 sensor.
Now the check engine light is on and don't know why? Anyone have ideas on what it can be. I allready reset the battery.
Old Jan 25, 2004 | 12:53 PM
dragman99's Avatar
Default Re: help.. (cegleitz)
i tried extending my wires one time to fit a y7 manifold on my y8(don't ask why), but i couldn't get to work either. i think the wires have to be the same exact length.
Old Jan 25, 2004 | 01:00 PM
cegleitz's Avatar
damn. what did you end up doing? did you get an o2 sensor extension? I couldn't find any. Someone said that dc sport made one for like 20 bucks, but i couldn't find it.
Old Jan 25, 2004 | 01:08 PM
JDMlyfestyle's Avatar
did u do a ecu code check on the car. check the ECU thread in my sig and that should help you with some of your problems
Old Jan 25, 2004 | 01:32 PM
cegleitz's Avatar
i've never had to check the code on my car. On my brothers prelude there is a place under the steering wheel that you stick a paper clip in and it blinks the code. How do you do it on the 00 civic. thanks.
Old Jan 25, 2004 | 01:43 PM
Pete_SI's Avatar
Default Re: (cegleitz)
https://honda-tech.com/zerothread?id=682412
Old Jan 25, 2004 | 02:17 PM
cegleitz's Avatar
is it in the same spot on an 92-95 as a 2000?
Old Jan 25, 2004 | 02:25 PM
Status Sean's Avatar
it will be a green plug next to the ecu wiring harness
Old Jan 25, 2004 | 02:41 PM
cegleitz's Avatar
so it's under the glove box and not under the carpet
Old Jan 25, 2004 | 02:46 PM
illicon2003
Guest
Posts: n/a
did you reset the ecu before work? Or have you reset it since?
Old Jan 25, 2004 | 02:49 PM
cegleitz's Avatar
i disconnected the battery
Old Jan 25, 2004 | 03:03 PM
cegleitz's Avatar
is that the same as reseting the ecu?
Old Jan 25, 2004 | 03:08 PM
dragman99's Avatar
yes.
Old Jan 25, 2004 | 03:10 PM
cegleitz's Avatar
k, just making sure
Old Jan 25, 2004 | 03:59 PM
SouthSide's Avatar
You should check the codes first. (Not with the paperclip method). There is an OBD connector somewhere under the dash. Usually by the steering column. Either find a buddy with a diagnostic tool, go to a shop, or you can usually buy a cheap one at a parts store that will work for about $40-50. Once that is done, then you'll know if it is the O2 or not. Then you can start diagnosing it properly. Good luck!
Old Jan 25, 2004 | 04:03 PM
HXvtec's Avatar
Default Re: help.. (SouthSide)
make sure that u put the wires color to color. i remember when i did this and i threw a CEL. come to find out that one of the wires was hooked up wrong. after that no code.
Old Jan 25, 2004 | 04:16 PM
cegleitz's Avatar
well, i decided to disconnect all of my battery pos and neg and waited like 2 hourse, plugged it back up, turn it on, no light.....for now. Haven't go to drive it yet because of ice on the roads!! Damn ice. Thanks for your alls helps
rowo87
Honda Civic (2001 - 2005)
Mar 31, 2010 10:38 PM
greyejcoupe
Oct 3, 2009 10:48 AM
Gen5lude
Mar 29, 2006 12:10 PM
JdoggsGSR
Jun 23, 2001 07:45 PM
