help.
help.
sup guys. Im a nub here and I need some help Im doing a 95 gsr swap to my 97 cx and my question is about the wiring what do I have to worry about? as far as v-tech goes and the knock sensor? does anyone have diagrams with pics. or any sites that can help me?.
um yeah....you're going to put an obd1 engine in an obd2 car, I'd say there is lots of wiring you're gonna have to do, and then you'll be lucky to pass emissions. The vT4k will be a simple 3 wire run to your ecu...searching on here will find all the answers you're looking for, just as the previous poster has pointed out.
HT Order of Merit
Re: (Pioneer162)
OBD1 into an OBDII will NOT pass emissions anyplace... unless you run it as OBDII.
Search dude, there is TONS of info here, and elsewhere covering this.
Re: (JDM_Ej)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDM_Ej »</TD></TR><TR><TD CLASS="quote">OBD1 into an OBDII will NOT pass emissions anyplace... unless you run it as OBDII. </TD></TR></TABLE>
FALSE! Ohio law says that if the OBDII interface plug is inaccessable for ANY reason, it will be givin a tailpipe test instead.
on-board diagnostics computer....obd1 just flashed a series of codes on your check engine light, obd2 can actually be hooked into by computers so that data and error codes can be retrieved.
thanx guys about the emissions test Im not worried about what Im worried about now is the wiring for the obd1 and obd2 problem. Where can I get diagrams for that matter. I really need my car back.
02-14-2008 08:44 AM
THugluv423
06-04-2006 06:02 PM
