Having promblems with my gsr
when i hit high rpm's my exhaust shoots out high amount of smoke!!! has anyone had this problem???!!! and there's oil in my spark plugs!! would really like some help on this cheea
Ek Forever y0!
Re: Having promblems with my gsr (GSR_hatch936)
Could have done a couple of things.
Floated valve IE bent valve.
A seal could have busted.
It's likely you're reving a little too high too often.
And if you're staying in vtec too long that can be detrimental to you're engines health.
Please don't tell me you have a vtak controller either.
so why would there be oil where my spark plugs are at and its around the plugs and on my plug wires!! i havent checked the spark plug but just pulled the wires out!
Imperious: Mod of Valor
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GSR_hatch936 »</TD></TR><TR><TD CLASS="quote">so why would there be oil where my spark plugs are at and its around the plugs and on my plug wires!! i havent checked the spark plug but just pulled the wires out!
Again, remove your valve cover and check your O rings.
Apreciate the help man, ima chek it out ima do that right now might post a pic could this be holding back my car from alot of power?
Ek Forever y0!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GSR_hatch936 »</TD></TR><TR><TD CLASS="quote">Apreciate the help man, ima chek it out ima do that right now might post a pic could this be holding back my car from alot of power? </TD></TR></TABLE>
you don't have much power to begin with.
How does it feel when it drives?
o damn, misread something in your post. Yeah, there is a O-ring seal that keeps oil from getting in your spark plug hole, they go bad sometimes. Easy and cheap fix. Again, JDM-EJ1 speaks the truth
Something like that no, but you'll need to get it fixed. I would worry about getting your car fixed, before you start worrying about 'power'.
i bought this car from a guy who was lazy to fix the car i guess he didnt do nothing to the car he just paid somebody im impressed by the way it pulls right now this is wat it has:
Engine:
B18C1
Slight Port and Polished Head
CTR Exhaust Cam
Crower Intake Cam
Crower Valve Springs
Crower Retainers
AEM Cam Gears
B&M Fuel Pressure Regulator
CTR Pistons
DC 4-2-1 Header
Custom Exhaust
DC Sports Short Ram Intake
No Name Front Strut Bar
Clutchmasters Clutch
GSR Tranny
Chipped P-28 ECU
Engine:
B18C1
CTR Exhaust Cam
Crower Intake Cam
Crower Retainers
AEM Cam Gears
CTR Pistons
DC 4-2-1 Header
Custom Exhaust
GSR Tranny
Chipped P-28 ECU
Re: (ekb16a)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ekb16a »</TD></TR><TR><TD CLASS="quote">yah oil rings but if u fix that then u still get smoke ur piston rings </TD></TR></TABLE>
what? his rings are probably fine. The oil leaks down the threads on the spark plug and into the combustion chamber.
.:urbandc2:.
15
12-08-2008 12:28 PM
