Hasport Mount 96-00 B swap Question
I'm currently doing a B series swap in a 99-00 chassis, and will be going with the hasport mount kit. Will I need to keep the EM1 brackets or does anyone know if the mounts bolt directly to the chassis and subframe?
To be more specific:
https://www.hondapartsdeals.co...5.gif
Numbers 7 and 6
Also, will a mount kit with 62A be enough to get rid of my torque mounts?
Thanks.
Modified by Fresh'86 at 4:09 AM 3/13/2008
Numbers 7 and 6
Thanks.
Re: Hasport Mount 96-00 B swap Question (Fresh'86)
You still need 6 and 7 and you need the bracket that connects to the motor from an 99-00 Si.
And yes you could ditch the torque mounts.
Re: Hasport Mount 96-00 B swap Question (Luserkid)
Thank you sir
I have the third bracket as well, I just didn't mention it since I knew that one was going to stay 100%. I bought tq mounts and brackets and was going to stick with OEM mounts but changed my mind and decided to go hasport..
Thanks for the info
Thanks for the info
H-T Premium Sponsor
I would still run the torque mounts with the Hasport mount kit.
Keeps the engine from entering the passenger compartment in event of a crash.
