Harmonic balancer major problem.
Old 11-26-2008, 09:51 AM
TravisCadello's Avatar
Default Harmonic balancer major problem.
ok, my brother lost his harmonic balancer it fell off on the highway on his 93 civic lx d16z6 v tec and he put a new one on and it just spun and i told him its missing the woodruff key to hold it in place. so he jb weld it and it fell off a day later. he gave me the car for 100 and i pulled the motor yesterday so i could drop it into my 92 4 door civic and make it standard.
Well the timing belt pulley thingy on the crank the end of it has a metal thing comming out of it for the harmonic balancer to slide onto then bolt on. well its not their nomore it broke.
is their a way of changing the whole gear pulley by its self or is it part of the crankshaft?
Old 11-26-2008, 11:51 AM
packman5280's Avatar
you mean at the end of the crank, past the timing gear, there is no place to attach the pulley? check to be sure the timing gear didn't just slide off a bit, but the end of that piece is part of the crank. if it's gone, you'll need a new crank. again, this is going from memory on a b16, so i may be wrong, but bump for you anyway.
Old 11-26-2008, 12:05 PM
Seagull Management
94EG8's Avatar
The gear itself is seperate and can be replaced on its own, but its sounds like your brother broke the crankshaft off after the crank pulley, only fix there is a new crank. D15B7 crank wont fit either just in case you were wondering, main and rod journals are smaller.
Old 11-26-2008, 01:15 PM
i was thinking maybe the gear just isn't pushed on all the way, and there is big glob of jb-weld keeping it from going all the way back, it might look like the end of the crank was broken off.
downeyballz
05-15-2007 03:16 PM
Sketch_hs
03-02-2006 06:40 PM
DOHC_C-REX
03-24-2004 11:51 AM
ITR9788
01-20-2004 02:51 AM
gulf imports
08-16-2003 02:26 PM
Quick Reply: Harmonic balancer major problem.
