Hard shifting and locked out of gear?
Started about 2 weeks ago, gotten worse everyday.
Clutch fully engaged and it won't go into gear. Sometimes it will go into 4th with difficulty. Have to force it into first (this just started yesterday). MC is fine, no leaks. No apparent leaks from SC. Res. is full. Bled the clutch, no air came out and it didn't help any. Clutch isn't slipping at all. First has to be forced 90% of the time, second is hard getting into. Third grinds about 40% of the time, fourth and fifth are fine.
I'm ready to pull the trans and pull it apart. Have two good shift forks incase they're bent.
Any ideas? Experience only.
Re: Hard shifting and locked out of gear? (maynards_ek)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by maynards_ek »</TD></TR><TR><TD CLASS="quote">Throwout bearing. </TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by -JSpecEk*9- »</TD></TR><TR><TD CLASS="quote">you got fluid in the trans?</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by j_kevin_ca »</TD></TR><TR><TD CLASS="quote">might be the clutch, it happened to me.... coz one of the spring came out from the disc</TD></TR></TABLE>
COULD also be the sliders in the trans?
what kinder tranny fluid you using?
MiraiZ
08-12-2003 06:18 PM
