h22a4 for my ek
h22a4 for my ek
well i bought a h22a sh for my ek... i have it all install but now the harness won't reach the passenger side panel, what can i do.? i would beleive the code is h22a4
Modified by pornfreaktommie at 12:15 AM 9/7/2007
Re: h22a4 for my ek (slow ej1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by slow ej1 »</TD></TR><TR><TD CLASS="quote">extend it </TD></TR></TABLE>
x2
x2
Re: h22a4 for my ek (pornfreaktommie)
you can if you want to - wire is wire..its all made from the same **** just has different colored jackets...a spool of speaker wire is cheap and will solve your issue..but if you want to play it safe, its understandable.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pornfreaktommie »</TD></TR><TR><TD CLASS="quote">well i bought a h22a sh for my ek... i have it all install but now the harness won't reach the passenger side panel, what can i do.? </TD></TR></TABLE>
reach where? the Big blue plug? or the small plugs like the vss or the o2 wires?
that harness should work fine, you should only have to extend tps alt iac and maybe one or two more im forgetting.
are you useing the EJ harness or the SH harness?
Re: h22a4 for my ek (oneludesol)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pornfreaktommie »</TD></TR><TR><TD CLASS="quote">would it be better off to just get a harness from the usdm motors? or from the prelude</TD></TR></TABLE>
hold up you said you have an h22a4 swap in the topic title then in the post you said you have an h22a...........................which one do you have tell the truth becuase you cant use an a4 in the swap , and you cant use the jdm harness on the usdm chasis
Re: (slow ej1)
Damn Man, is that what i have to look fopward to when i do my H22 Type S swap. that wiring looks like a cluster F**K. im trying top figure out what you guys are talking about. the engine is going to come with a wiring harness ? then i guess the problem is hooking it into the exsiting Si harness ? is there anything thats different between the two, or is it just plug and play ? somebody please explain the whole wiring harness thing to me.. ??
GDD's Dr. Phil?
Re: (PhoeNix007EG)
hasport... send them the new motor harness and the harness that is in your car at the time, and you will receive a perfect length plug and play harness.
RhdRicheeee
02-24-2007 11:18 AM
gulf imports
06-12-2004 08:36 PM
