h22 swapped ek no spark no fuel
so i recently decided to ditch the b16 turbo and go with a h22a4 in my 99 si. ive got the motor in and everything hooked up.between the car harness and the engine harness there are 4 clips inside the car and the ecu that came with it only has 3 first off before i explain the problem. i am not getting any spark/fuel. i ran a wire from fuel pump to a direct power and it will kick on but only then.but still cant get spark.i pulled a plug out kept it in the wire and grounded it to the car and no spark so could be anywhere from the ignition switch to the spark plugs.just need some help nvr done a h swap and am pretty aggrivated so any help is appreciated.
5exy_Ek
10-09-2010 07:42 PM
mugenhatch92
17
06-26-2005 05:53 PM
