Guess my HP!! I'm too poor to Dyno it:[ help me out
Old Mar 28, 2010 | 10:45 PM
  #101
TypeRMOBBiN209's Avatar
Default Re: Guess my HP!! I'm too poor to Dyno it:[ help me out
hahaha 170-180? you make as much as my itr
Old Mar 28, 2010 | 10:51 PM
  #102
v8killaz's Avatar
Originally Posted by freeagent
torqueless wonder or not, they are still weak *** ****.
and yes the d16 is probly a rotating pile of ****, all im saying is neither of them will be fast without forced induction or compleltly built, a b16 running 15s is not fast either,
and really a mustang running low fourteens is not fast,
b16 running 14's is fast for a fwd 1.6 litre 4 banger making 160 to the wheels
but anyways the z6 u wasted ur money on is bnot going to go any faster with boltons, could have went with an ls which happens to be my favorite swap. cheap and alot of tq.
and no way in hell u will beat a b16 with ur d16, either one shoudl never be raced because they both are slower than family cars
Old Mar 28, 2010 | 11:00 PM
  #103
ninjasam87's Avatar
TRIAL USER
yeah I agree with everyone else maybe 120 at the wheels. The motor may come factory 130, but that's at the flywheel. Due to friction and transfer of power from the motor to the tranny to the wheels, you lose about 15% of power, so in actuality, the brake horse power is less that what the factory tells you. Basic bolt-ons like intake and exhaust never give you the 10-15 horsepower they promise, a car can have as many bolt-ons as you can get in that engine bay, but they never put out the full potential without a chipping ecu and a good dyno tune session.
Old Mar 28, 2010 | 11:34 PM
  #104
Kidnkorner's Avatar
Since when does a B16 make 160hp to the wheels? The B16A make in the neighborhood of 140-145 and the B16A SiRII makes around 148-152.
Is this a B16B you are talking about?
Old Mar 28, 2010 | 11:50 PM
  #105
mrharmonic's Avatar
swap to a b and save your time on a single cam slammer lol
Old Mar 29, 2010 | 12:04 AM
  #106
rickkane's Avatar
Originally Posted by Linked
i'll be glad to threadjack!!!
since we're talking about power losses and consumpions,
when going from an oem weight flywheel to a lightweight 7lb
how much hp you think makes it to the wheels then?
Sorry there hotdog, but changing flywheel weight doesn't make any extra hp. It does help the engine rev quicker, which will also help the gearbox accelerate quicker, so it would seem like the car is making more power, which it kinda is, but it's really not. Get it? Check this out if you're still confused....
http://www.uucmotorwerks.com/flywhee...heel_works.htm
Old Mar 29, 2010 | 01:08 AM
  #107
v8killaz's Avatar
im saying a b16 car in general with basic boltons
i know no b16 makes that much at the wheels im just saying the average b16 u come across has basic boltons that should be somewhere around the 160whp range
u can run mid 14's with a stock b16 in a lighter chassis though
Old Mar 29, 2010 | 01:10 AM
  #108
v8killaz's Avatar
i would think a lightened flywheel would pu more power to the wheels because of the drag of heavier parts though wont you think.
just like heavier wheels. not alot maybe like 1hp or less
Old Mar 29, 2010 | 01:28 AM
  #109
rickkane's Avatar
That's kinda what I was saying. Since I wrote that, I actually stumbled across
an article claiming dyno results of 8 hp and torque!
http://www.importtuner.com/tech/impp...ion/index.html
So I must insert foot in mouth here. Oops.
Old Mar 29, 2010 | 02:26 AM
  #110
JoeRaceDriver's Avatar
Originally Posted by masterEF
ok how about we just agree that people who race in a straight line dont know how to drive a car if there life depended on it....
Old Mar 29, 2010 | 04:10 AM
  #111
ChokolAwt's Avatar
tl;dr you all got trolled
Old Mar 29, 2010 | 04:23 AM
  #112
ej_man's Avatar
Originally Posted by 1phatEG8
D16Z6
* Found in
o 1992-1995 Honda Civic EX (Japan Market)
o 1992-1995 Honda Civic EX, EX-V(US)
o 1992-1995 Honda Civic Hatchback Si,(US)
o 1992-1995 Honda Civic ESi (European Market)
o 1993-1995 Honda Del Sol Si (US)
o 1992-1995 Honda CRX del Sol ESi (European)
+ Displacement : 1,590 cc (97 cu in)
+ Bore and Stroke : 75 mm × 90 mm (3.0 in × 3.5 in)
+ Rod Length : 137MM
+ Rod/Stroke : 1.52
+ Compression : 9.2:1
+ Power : 125 hp (93.2 kW, 127 ps) @ 6600 rpm
+ Torque : 106 ft·lb (14.7 kg/m, 144 Nm) @ 5200 rpm
+ Piston Code : P28
+ Volumetric Efficiency : 87.68%
+ Redline : 7200 rpm
+ Fuel Cut : 7411 rpm
+ VTEC engagement : 4800 rpm[2]
+ Fuel Control : OBD-1 MPFI
+ Head Code : P08
+ ECU Code : P28
I'm confused, 125hp from the factory + a **** load of bolt-on's should add up to more than that.
Can someone please explain?
thats to the flywheel no to the wheels you loose alot of power as it makes its way throught the motor all the way to the wheels i'd say a stock Z6 makes like 98whp
to see what u made instead of dyno tuning it you can get a dyno pull over here its like $70 for 3 pulls
Old Mar 29, 2010 | 04:27 AM
  #113
Jimster480's Avatar
160 - 15% = 24hp Power loss. More like 136WHP at max.
Old Mar 29, 2010 | 04:29 AM
  #114
ej_man's Avatar
Originally Posted by 20-EM2-05
Ditch those MSD crap. OEM's are way more reliable.
MSD, will just cause you more headache.
Amen i'm dealing with that right now lol
Old Mar 29, 2010 | 04:39 AM
  #115
ej_man's Avatar
b16s are weak as ****.
really are r u serious? mine made 164whp at 8000rpms but it was still pullin the tuner didnt want to go higher than stock rpms but he told me i could easily make well 170-175whp AND ALL I HAD WAS ITR CAMS STOCK BOTTOM END i wreck gsr hathies so please there no crap its just the tourqe that sucks lol
Old Mar 29, 2010 | 04:43 AM
  #116
BryanM.'s Avatar
Resident Gearhead
Probably.
Originally Posted by Jimster480
its very possible hes smoking b series kids. Most of the B ***gots have no idea how to drive. I watch them every week at the track, just smear the name of Honda with their shitty expencive setups and their even shittier times.
You have started profiling people by the engine they have? I would love to see the formula you have developed to accomplish this.
D-series owners: Know how to drive, keep the Honda name sacred and spend less money doing it?
B-series owners: Do not know how to drive, have shitty expensive set-ups and "smear the name of Honda" every time the show up at the track?
H-series owners: (Would need to see you proprietary formula to fill this in)
K-series owners: (Would need to see you proprietary formula to fill this in)
You sir, have just shown your true colors. I await an intelligent response from you regarding this matter.
Old Mar 29, 2010 | 04:55 AM
  #117
BryanM.'s Avatar
Resident Gearhead
Nevermind, don't bother.
Old Mar 29, 2010 | 05:26 AM
  #118
Jimster480's Avatar
Originally Posted by mcvtec
Probably.
I didnt say all B series owners dont know how to drive. But that is the norm for people around here. They go to the track and just make Honda owners look like ****ing retards. They cant launch, dont know how to get traction after they launch, and they constantly miss gears, or shift slow as ****. And then you talk to them about why their car is slow and they are like no its so fast that I just cant get traction. When they are racing on walmart tires and powershifting while they are spinning tires. The sad thing is that its not even the same people every week.
But I remember when a guy with a B20 on drag radials went to the track, his best time was a 8.9 in the 1/8th, and he beat every one of the idiots which were there that night.
There are people who show up with no exhaust, or open header and just make a **** ton of noise and go nowhere. Most of them have the mentality of "I have a B series, my car is fast".
Normally people with K series (few people have K's) actually know how to drive, because they are usually way more experienced than the idiots with their B swaps. Since its not as easy to do a K swap. And the only H series I have seen are people with preludes with super loud ricey exhausts, and always with **** times.
I have seen some people with D series who dont know how to drive. But usually people who come to the track with D series (especially ones with light mods) usually know how to drive. And they are usually racing because they are saving up for a swap or boost and want to see how well they do. Or they cant afford to do expensive mods, so they just focus on driving.
I'm not sure how it is in other places, but thats basically how it is here.
Old Mar 29, 2010 | 06:04 AM
  #119
ChokolAwt's Avatar
lemme change my previous post. trolls trolling trolls being trolled by trolls.
you idiots are arguing about stereotypes. has that EVER gotten ANYWHERE in the past?
Old Mar 29, 2010 | 06:18 AM
  #120
Pothole987's Avatar
great way to change the thread topic.
but anyways you problaly have 106whp
Old Mar 29, 2010 | 06:19 AM
  #121
Jimster480's Avatar
there is no way that ITR cams gave you 30HP.
Old Mar 29, 2010 | 07:03 AM
  #122
forcefedferio's Avatar
Jimster, I know you and i have had this conversation before, and i understand that you are speaking of just how it is in your area. However it isn't like this everywhere, for instance around here all the ricers have stock D-series with ebay exhausts that sound like raspy poop. Drag racing in a honda isn't real big here, and most are just looking for good reliable all motor power, hence a b-series of any configuration.
If you are going to continue making this brash generalization of B-series owners you need to make it clear everytime that you are stating your opinion of people around you in your area.
I don't believe i should be hunting a d-series swap for my R because if i have a B in it i'm a ***got.
allhonda
Jul 14, 2007 09:27 AM
newfie24
May 23, 2006 02:21 PM
yoshi234
Apr 29, 2002 08:19 AM
DevSys
Aug 30, 2001 05:36 PM
