GSR Swap
GSR Swap
Hi all,
Im planning on swaping a OBD1 GSR into my 93' Civic HB DX. I was just wondering on a couple things that I would need.
And as for a place to egt it from, would it be better to go local so I can take a look at the engine before they send it to me.
The swap comes with the following parts:
Complete Block Head
5 speed Transmission
jdm ECU (P72)
jdm Wiring harness OBD1
Distributor
Exhaust Manifold
Down pipe
Intake Manifold
Fuel Rail
Injectors
Sensors
Starter
Half Shaft/Intermediate Shaft
Alternator
A/C Compressor
Power Steering Pump
Throttle Body
Shifter Linkage and Axles
stock motor mounts
+LSD if they have it
Since the swap comes with jdm Wiring harness OBD1 do I need to buy a harness from rywire ( http://rywire.com/store/9295-c...1e6d6 )
Other then that are there other things that I need?
Im going to be replacing the radiator and fan. ANything else?
Thanks.
Complete Block Head
jdm ECU (P72)
Distributor
Exhaust Manifold
Down pipe
Intake Manifold
Fuel Rail
Injectors
Sensors
Starter
Alternator
A/C Compressor
Power Steering Pump
Throttle Body
stock motor mounts
Thanks.
Abius
21
05-27-2008 04:38 PM
likenother
03-18-2006 08:35 PM
