are gsr and si ecu's similar?
about to test out a si ecu in my gsr just for the hell of it this week......is it gonna run any worse?
1.6 and 1.8 hmmm
any comments guys?
1.6 and 1.8 hmmm
any comments guys?
Re: are gsr and si ecu's similar? (gtowni3)
Assuming both computers are the same OBD designation, do you have a different intake manifold? How are you going to open the secondarys?
Your ECU helps activate the secondarys in your intake manifold. If they don't open, you're going to lose quite a bit of power on the top end. You'd have to rig it to open up.
I had a p72 (obd1gsr) in my hatch for my ls/vtec and swapped it for a p30 (obd1b16) i drove it for 5 minutes and decided on my way home i was gonna stop at the atm and get some money to offer this kid for his ecu. Car Def Pulls harder.
Re: are gsr and si ecu's similar? (rodrez)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rodrez »</TD></TR><TR><TD CLASS="quote">Your ECU helps activate the secondarys in your intake manifold. If they don't open, you're going to lose quite a bit of power on the top end. You'd have to rig it to open up. </TD></TR></TABLE>
incorrect. the secondaries are open by default. the ecu triggers vacuum to the secondaries and then releases it at the set rpm...
I've run a si ecu on a gsr for quite some time with no ill effects, vtec is more prominent when it kicks (higher revs) didn't notice anything as far as actual performance...
btw, unless you switched to a different IM or removed the butterflies completely, you're only hurting yourself through loss of torque
Re: are gsr and si ecu's similar? (miahmouse)
ahhhhhhhh too bad .....ecu doesnt fit cuz its obd2b and i have obd2a harness.....DAMN!!!..........but i am getting rid of it itr ecu 2moro and putting a stock gsr obd2a ecu, since my motor is bone stock besides intake, fuel pump lol.........skunk2 im is being put on this friday
any comments if the car will perform better with the gsr ecu??
gracias
gracias
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gtowni3 »</TD></TR><TR><TD CLASS="quote">ahhhhhhhh too bad .....ecu doesnt fit cuz its obd2b and i have obd2a harness.....DAMN!!!..........but i am getting rid of it itr ecu 2moro and putting a stock gsr obd2a ecu, since my motor is bone stock besides intake, fuel pump lol.........skunk2 im is being put on this friday
gracias </TD></TR></TABLE>
what did I tell you earlier
