GSR seats into an EG Civic Hatch (pics)
The Integra seats are from a 94 up 2door, and all four mounting bolts lined up into my VX. The rear backs also mount perfectly without modification, however, using the 2door Integra rear cushion leaves about a 3 inch gap along the back and about a 2 inch gap on the sides. To curb this, most will suggest you use a cushion ONLY from a 4door model Integra.
Re: GSR seats into an EG Civic Hatch (Ekay)
Very, Drivers seat even has 'poor mans' lumbar support. Rear cushion is a little firm, not nearly the amount of foam that comes with the civics. Easily fixed though!
Re: (NYCautosport.com)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NYCautosport.com »</TD></TR><TR><TD CLASS="quote">thats amazing, you're probly the first one to ever do this!</TD></TR></TABLE>
Nice easy title to search and pics to go with it for those interested.
And yes, you are a Jackass.
Guest
Posts: n/a
Whats with all the haters?
F*CK THIEVES!
Re: (ARIZONA)
exactly..always talkin **** behind the screen. anywaise..seats look great. did those rear speaker grill come stock like that or did u get dem somewhere?
Re: (hasback_00)
Yeah, the Seats are nice. I just did black leather, wish I would've done cloth now. Those look like the same place the EG Si speakers go... Custom cut and mount? Look good anyway.. what speakers are those???
Re: GSR seats into an EG Civic Hatch (ARIZONA)
Ek's are a little more complicated. However, backseats from the 92-93 GS/GSRs will fit in just fine with no gap. With DC seats you need to drill out the hole in the sidewalls for the seat pin to fit in. for the middle i used a wood dowel. The gaps don't bother me much anymore. Front seats you need to replace the rails with the original EK rails.
your interior looks good though.
Looks like mine used to, I had the exact same seats from a 94 GSR in my 92 VX. I recently got some USDM 00 ITR fronts, so out with the GSR's. So do you have the 4 door Integra rear lower cushion in? I've been debating on what to do about the rear, possibly have my stock ones reupholstered so they match and line up perfectly. I guess that would be my option since they don't make a 4 door ITR. I can't justify buying a 2 door ITR rear seat when it doesn't fit properly.
Re: GSR seats into an EG Civic Hatch (VTECVillain)
i have black gsr leather in my car....they are ok....the rear lower doesnt sit right at all i am thinking bout just having the stock section done in leather to make it fit right......but ur interior looks good keep u the good work.
Re: GSR seats into an EG Civic Hatch (zseeanz)
I just put a set of black 97 GSR Cloth seats into my Si. Fronts fit perfect (of course), the upper backs fit perfect, but i too ran into the problem of the rear bottom cushion fitment. What I did was cut off all the Integra mounting points that are on the bottom of the seat and I bent and welded on new brackets. The sides still have a gap, but the gap between the seat back and cushion is about 1-2cm instead of 1 inch.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by VTECVillain »</TD></TR><TR><TD CLASS="quote">Looks like mine used to, I had the exact same seats from a 94 GSR in my 92 VX. I recently got some USDM 00 ITR fronts, so out with the GSR's. So do you have the 4 door Integra rear lower cushion in? I've been debating on what to do about the rear, possibly have my stock ones reupholstered so they match and line up perfectly. I guess that would be my option since they don't make a 4 door ITR. I can't justify buying a 2 door ITR rear seat when it doesn't fit properly.</TD></TR></TABLE>
they have 4 door ITR's in JDM land...just pick up some JDM 4 door ITR rear seats.
you gotta love the HT sarcasm....
