gsr radiator on eg b16
I noticed the gsr radiator I got has more hose plugs then the half size b16 radiator...is it possible to use the gsr radiator on a b16 motor and if so how?
Are you referencing the two small ones at the bottom? Those are for automatic transmission fluid and shouldn't be messed with unless the car is an automatic. Regarding actually using the radiator, it's been done numerous times and I'm sure somewhere here on Honda-Tech there is a writeup.
Re: (92b16vx)
I use to have a b16 radiator but some ****** backed into my car and cracked my radiator in the process so I bought a gsr radiator but it has 1 large hose *** on the top 1 large one on the bottom...then 2 small hose **** on the bottom and 1 on the top where the coolant goes in...so do I just need to plug these extra **** or will it still not work?
Re: (mingbling96)
Yeah I can cut off the ac brackets and stock radiator brackets and custom weld some at the bottom of the core support...just gotta make sure the un-used **** can be plugged up or not?
Re: gsr radiator on eg b16 (skaterguy)
So before I go out and do this tonight, is it ok that I plug the extra holes on the radiator with some kind of sealent?
streetracerof06
02-13-2006 01:14 PM
Chicano
04-19-2005 04:17 PM
