gsr pistons in b16a2 block??
justy like the title says, a few months ago i blew a piston in my b16 motor and i have some je pistons out of a gsr and i was wondering if they would work in my block??
Re: (pdiggitydogg)
wil they drop right in on my b16 rods? or is there anything different i have to do? would it be a direct drop?
Aftermarket companies do not make "gsr" or "b16" pistons.
They just make Honda b series (81mm+)
So the answer again, is yes they are a direct install. I recommend you hone your block and have it inspected for damage before you swap anything over
Darth ModerVader
Re: (pdiggitydogg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pdiggitydogg »</TD></TR><TR><TD CLASS="quote">Aftermarket companies do not make "gsr" or "b16" pistons.
So the answer again, is yes they are a direct install.</TD></TR></TABLE>
That's not entirely true. Assuming the pistons are designed to be a direct fit for the stock GS-R rods, they won't fit the stock B16A rods, and vice versa.
Also, depending upon how "aggressive" the pistons are, you may end up with a lower compression ratio than what the B16A pistons were providing.
Re: (Padawan)
when you say they won't fit the gsr rods what do you mean? because i have crower gsr rods and some stock b16 rods? how can i make them work in my b16 block?
Re: (boricuaef9)
they are je 9.1 pistons and crower gsr rods. im trying to get my car running the cheapest way possible..because the b16 blew a piston.. nd i don't have alot of money..
Darth ModerVader
Re: (boricuaef9)
You will have to mill the B16A rods in order to install GS-R pistons on them.
You'll also end up with quite a low compression ratio, so unless this is a turbo setup, I'd recommend choosing a different solution.
you know ive never heard/seen that before
when i was looking at pistons, wiseco and je all had the same part numbers for any b series just with various piston styles (flat, dish, dome).
Darth ModerVader
Re: (pdiggitydogg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pdiggitydogg »</TD></TR><TR><TD CLASS="quote">you know ive never heard/seen that before
when i was looking at pistons, wiseco and je all had the same part numbers for any b series just with various piston styles (flat, dish, dome).</TD></TR></TABLE>
JE does appear to list the same part numbers, so I'm curious what rods they're designed for.
I know that in the case of OEM GS-R or Type-R pistons, stock B16A rods must be milled in order for the pistons to be installed.
Darth ModerVader
Re: (boricuaef9)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boricuaef9 »</TD></TR><TR><TD CLASS="quote">im sorry im not quite understanding you what do you mena by mill?</TD></TR></TABLE>
Material must be removed from both sides of the small end of the rod in order for the piston to fit. This is true for OEM pistons/rods, but I'm not certain what the JE pistons are designed to fit.
As for the compression ratio, even for a turbo setup, it will be quite low with the JE pistons.
aLlmoTorcoUpe
Engine Management and Tuning
02-06-2009 09:31 PM
