GSR master cylinder...bolt in? worth it?
i'm getting 11.5" front brakes, and want to upgrade my master cylinder while i'm at it. 92 HB CX. will it bolt in? is it worth it?
Re: GSR master cylinder...bolt in? worth it? (hot_EF)
I believe you will also need to change out the brake booster. I'm not sure if it's worth it unless you plan on switching to rear disc, or upgrade to 4 piston calipers. All the larger GSR parts do is push more fluid through the lines, which is only really needed if you have major upgrades. If you are looking for better pedal feel, and solid braking, just upgrade to SS lines. It's an cost effective, and a pretty simple install which make your brakes feel damn good. But that's just my somewhat rookie opinion.
Re: GSR master cylinder...bolt in? worth it? (VegasVTEC)
Former Moderator
Nope. It's an ABS unit and will require a double flare of the rear fitting because it uses an ABS fitting.
BUT!
Buy any 1994-1997 Integra booster and an Integra RS master cylinder. It bolts straight up and requires no line bending or re-flaring. Your Civic lines will screw in just like stock. The RS had no ABS, so it uses the normal lines and fittings like you CX does.
BUT!
Re: GSR master cylinder...bolt in? worth it? (B18C5-EH2)
BUT!
BUT!
Leb_CRX
01-31-2005 08:40 PM
I just did a rear disc brake swap, Do I need the brake booster and master cylinder from a 4 disc bra
Sinner
04-12-2004 07:00 PM
bruvaman
07-09-2002 07:19 PM
jonnybravo
05-29-2002 07:08 PM
