GSR gauge cluster in EG?
New User
I have a stock 93 Honda civic Cx and i was wondering if i can somehow get a GSr cluster in my car b-c im gettin my motor soon and i dont have a RPM gauge. Is it difficult to do?
Re: GSR gauge cluster in EG? (SlooowEG)
It can be done. It's difficult, and most of us do NOT recommend it. BUT, it can be done. For example:
https://honda-tech.com/zerothread?id=168303
Shawn
Shawn
Former Moderator
Re: GSR gauge cluster in EG? (shawnhayes)
Actually Shawn, the link you posted shows the entire GS-R dash in a Civic, not just the cluster.
The cluster does NOT fit correctly and you'll either be cutting off your view of the temp and gas guages or you'll have to have this guy here on H-T make you one. He does a great job from what I've seen, but I can't remember his SN.
Just get the 1992-1995 Si/EX cluster. The tach goes to 9000rpms and isn't that all you'll need?
Re: GSR gauge cluster in EG? (B18C5-EH2)
tell ya what ill take some pics of my civic tonight for you....i just installed a 2001 GSR Cluster into my 99 DX Coupe
theres some information for now
***Intsall Guide*** http://www.fifthgearonline.com/installs/gsrcluster.htm
Hopefully, our warnings will be heeded.
Shawn
Former Moderator
I'm curious if the guy wants to swap the whole DASH or just swap the GS-R CLUSTER into the existing Civic dash.
Which one my friend?
it says cluster in the 1st post
This is a VERY ANNOYING INSTALL!!!!!!!!!!
- you will blow fuses alot ( i blew 1 fuse 6 times )
what you will have to do is re arrange every wire so that the cluster will work
It Is NOT plug and play!
also it does not fit in the space properly, so you will have to figure out how to make it stay......
if you are not wanting to do that sort of thing, then get a cluster from an EX, or LX....you dont have an SI....and that looks retarded in a NON SI car......
but if you are up to the challange go for it....it looks cool as hell......
heres mine
heres mine
i have installed a gsr cluster NOT DASH into my eg.. it was NOT a bolt on process either.. lots of rewiring, and time to make it fit so that it looks OK.. you can buy the on that a guy on the board makes and sell but i didnt have the $$ for it at the time so i did my own thing.. for the most part im happy w/ it and people see it are like wtf? here is a pic of it.. i have a good wiring diagram also if your that interested in doing the project..
New User
Re: GSR gauge cluster in EG? (95CivicEX)
Yea man, im really interested...please send me the wiring diagram. Do u have AIM or AOL? If so i would like to talk to you
check the CLASSIFIEDS forum, and do a search
there was a user from texas doing these swaps
he would of course use a GS-R cluster, and fit it into the civic glass plate, so where it would fit PERFECTLY like stock...the only thing u need is the wiring to do and that would be it !
good luck
good luck
Re: GSR gauge cluster in EG? (hybrider93)
I would just get a 92-95 Si/EX cluster and throw some 8200 RPM redline guage faces in it... waaaay easier.
Re: GSR gauge cluster in EG? (14eight)
thats how mine sits back there when the black plastic thing isnt in.....for now
***Warning Very Large Image***
http://www.fifthgearonline.com/p4230003.jpg
good luck
good luck
here is the link with the wiring diagram from my friend website: http://www.geocities.com/cinq112/gsrclusterswap.html
As for making it fits, you on your own man!!
good luck
[Modified by HybridFI, 6:30 AM 4/24/2002]
Re: GSR gauge cluster in EG? (VTEC CX)
i just put mine in about a month ago, the wiring is pretty easy as long as you have the right diagram, the first one i got was all messed up, what i did i took off the plastic cover, cut off all the edges off of the gsr cluster, then put it in, then i took the cover off of my friends old cx cluster from an eg, at just put in in front, it looks pretty good, you dont have to cut up your dash like the other guy did
Re: GSR gauge cluster in EG? (FifthGearOnline)
heres mine
heres mine
i think the Si cluster would do just fine.....he did mention he is gettin a new motor in the near future.
Re: GSR gauge cluster in EG? (dirtySOHC's)
I think he's talking about the glowing "SI" that's on the Si gauge... that looks kinda whack on a non-Si.....
heres mine
that is pretty damn funny considering you have a DX coupe with a GSR cluster........hmmmm.
heres mine
New User
Re: GSR gauge cluster in EG? (Jdmb18c)
Jdmb18c hey,do u have the right diagram that i can use to mine will look good and wont be as hard to do? i would really appreciate it..thanks...by the way....Honda-tech members...you guys are f*cking awesome...thanks
i know this is on honda-tech.com cause ive posted it a couple times... here it is again for everyone.. this is the correct diagram and everything works in my car so if it doesnt in yours, its user error..
teg's blue left side plug (13 pins)
1. blu tach signal
2. grn/org check engine indicator
3. yel/red oil pressure switch
4. NOT USED NOT USED
5. wht/blu charge indicator
6. NOT USED NOT USED
7. yel/grn coolant temp
8. blk ground
9. red/blu cruise (if you have cruise)
10. yel hot
11. NOT USED NOT USED
12. pink maintenance (not used)
13. NOT USED NOT USED
teg's right side blue plug (16 pins)
1. grn/red e.brake signal
2. red/grn high beam
3. grn/yel right turn
4. grn/blu left turn
5. NOT USED NOT USED
6. blk/yel power
7. red/blk power
8. red power
9. blu/red abs (not used)
10. grn trunk switch
11. org vehicle speed sensor
12. NOT USED NOT USED
13. blu/wht low fuel (not used, cant be used w/ out integra gastank and sensor)
14. yel/wht fuel gauge
15. lt grn/red door switch (not used, can be used w/ extra wiring to the doorpins)
16. red/blu seat belt
civic's left side grey plug (12 pins)
1. yel/wht fuel gauge
2. yel/blu vehicle speed sensor
5. wht/blu charge
6. yel/red oil pressure switch
7. NOT USED NOT USED
8. blu tach signal
9. NOT USED NOT USED
10. blk/yel power
11. red/blk power
12. red power
civic's right side grey plug (10 pins)
1. red/grn high beam indicator
2. grn/red e brake signal
5. grn/org check engine indicator
6. blk ground
8. yel hot
9. grn trunk switch
10. blu/wht seat belt
1. blu tach signal
8. blk ground
10. yel hot
6. blk/yel power
7. red/blk power
8. red power
5. wht/blu charge
8. blu tach signal
10. blk/yel power
11. red/blk power
12. red power
6. blk ground
8. yel hot
9. grn trunk switch
Re: GSR gauge cluster in EG? (fowler)
It doesn't glow.
It doesn't glow.
Re: GSR gauge cluster in EG? (ckkl)
This diagram is error free and I can back that up I installed mine about 2 weeks ago and EVERYTHING works 100%. You can work with the cluster and make it fit "near stock" but never "perfect". I retained the GSR plastic shield and trimmed only the top of the cluster. Just be creative and patient and you can make it turn out pretty good.
1 Post
It doesn't glow.
Yup my bad; was thinking of the cluster mods that some ppl did to make it glow... no Si in Australia (it's called VTi-R but same ****).
It doesn't glow.
Oh well, still looks better than a wobbly GSR cluster imo
Re: GSR gauge cluster in EG? (VTECVillain)
