GSR front sway on EG
Re: GSR front sway on EG (95excoupe)
Will a gsr front swaybar bolt up to a 95 civic ex, or do i need bigger brackets and have to drill new holes?
Re: GSR front sway on EG (Hybrid93Hatch)
i believe if you have a factory front sway..it should bolt right up...but parts needed are d brackets, bushings and end links
For mounting up the GSR front sway bar, you will need the GSR/ITR/99+ Si front lower LCA, the correct D brackets, bushings and the endlinks. Very easy to install. I am about to mount a GSR sway bar on my vx. When I get around to it, I will be doing a write up with pics. So stay tuned.
-Jeff C.
-Jeff C.
Re: GSR front sway on EG (Blue-Civic-Hybrid)
as long as you have the, above mentioned, LCA's with pre-drilled wholes and locking nut on the other
side....your set...assuming that you have the complete bar with proper endlinks, bushings and brackets.
i'ma about to do mine and also going to swap out shift linkage bushings as well...i suggest to think about that
also bc the shift linkage has to drop in order for front sway to go on....
just an idea...
just an idea...
GSR strut bar on Eg: https://honda-tech.com/zerothread?id=317949
But yeah, as long as you have all the brackets and bushings you should be fine since the ex front lca's already have the holes for a sway bar.
-Whitey-
11-08-2002 08:07 PM
