GSR del sol
GSR del sol
my battery light came on the other day so i thought it was my battery going weak and had it tested at autozone, it was bad so i replaced it with a new one and thought my problem was solved but it started to come on again and my idle would bounce up and down at stop lights... i had my alternator tested also that was not the problem and my connections are all good too, has anyone had similar problems?
Re: GSR del sol
havent had my battery light come on, but are u sure it wasnt ur check engine light that was ON? because ur rpm's fluctuating back & forth at idle will be ur idle air control valve goin bad so make sure, and see if its nor ur cel. hope this helped...
Re: GSR del sol
Make sure your belt is not stretched out and it could be the voltage regulator or corroded pig tails on the harness, i had that issue on my 91 b16 sedan and it was just a rusty corroded pigtail.
Re: GSR del sol
ok thanks for the replies i just cleaned out my iacv and it seemed to work at first but right before i got to work it started acting up again...ill give it a try
Re: GSR del sol
what started acting up again? the fluctuating idle or the intermittent battery light comming on? and did u replace the gasket that mates between the iacv and the intake manifold? also if u have a digital multimeter (if u dont I STRONGLY RECOMMEND you get one) measure ur battery voltage while the cars off, record ur reading, and then turn on ur car and measure the voltage again and this we help me diagnose ur battery problem
Re: GSR del sol
it ended up being my alternator after all so i picked one up, replaced the bad alt and everythings back to normal now...i first tested the alt by starting the car and disconnecting the negative connection on the battery to see if it would die which it didnt but i later found out that test is not accurate and so i took it to autozone to have it tested where it failed
Hawkrider
07-08-2003 02:53 PM
