gsr dash into eg problems...
Old 04-23-2002, 06:24 PM
SPOON_BeIgHtEeNsEe's Avatar
Default gsr dash into eg problems...
ok i finished my gsr dash into my eg... but i ran into some problems... whenever i signal the rpm jumps.... and the singals stay lite... i rechecked the wiring and everything is correct... could it be because im using a newer gsr cluster??? i used the civic harness... thanks
Old 04-23-2002, 06:25 PM
Kamin's Avatar
Default Re: gsr dash into eg problems... (SPOON_BeIgHtEeNsEe)
na sounds like somthing is grounding out or its a bad connection
reconnect the wires for that.
Old 04-23-2002, 06:51 PM
Mike B's Avatar
Used the Civic harness, what year speedometer is it?
Old 04-23-2002, 06:55 PM
Default Re: gsr dash into eg problems... (Crazy Bovine)
i think its a 98 its only got 20k on it... seller didnt know either... bought it for 25 bucks... hahaha
and one more thing my temp and gas gauges doesnt work either...
[Modified by SPOON_BeIgHtEeNsEe, 3:56 AM 4/24/2002]
Old 04-23-2002, 07:39 PM
Mike B's Avatar
98 or 99? If it is 99+ and you are using the OBD1 Civic harness, it will not work.
99+ Clusters RPM gauge were measured through the ECU, not via wire.
To simplify this, get the under dash harness.
Old 04-23-2002, 07:43 PM
lazyguy's Avatar
that year cluster dont work in an obd1 car, do u have any pics of the conversion though id like to see
Old 04-23-2002, 09:04 PM
Default Re: gsr dash into eg problems... (b18cURmama)
soon... im waiting for my spoon cluster to get here...
Old 04-23-2002, 09:07 PM
FifthGearOnline's Avatar
heres the wire order
Plug B
B1 - Yellow / Black - Seatbelt Light
B2 - Empty
B3 - Red / Blue - Fuel Gauge
B4 - Green / Yellow - 2 Silver Stripes - Low Fuel Light
B5 - Empty
B6 - Blue / White - Speedometer
B7 - Blue / Black - Trunk Light
B8 - Empty
B9 - Red - Brightness
B10 - Red / Black - Gauge Lights
B11 - Black / White - VSS
B12 - Empty
B13 - Green / Red - 1 Silver Stripe / Left Turn Signal
B14 - Green / Yellow - 1 Silver Stripe / Right Turn Signal
B15 - Red / Green - Not Available
B16 - Green / Red - 2 Silver Stripes - Emergency Brake
Plug C
C1 - Empty
C2 - Pink - Washer Fluid Level - Canada Only
C3 - Empty
C4 - Yellow - Dimmer
C5 - Empty
C6 - Empty
C7 - Black - Ground
C8 - Yellow / Green - Temperature
C9 - White / Blue - Battery
C10 - Empty
C11 - Yellow / Red - Oil Pressure
C12 - Green / Orange - Check Engine Light
C13 - Blue - Tachometer
Old 04-23-2002, 10:07 PM
Default Re: gsr dash into eg problems... (FifthGearOnline)
hey is plug b for the 16 and plug c for 13???
Old 04-23-2002, 11:55 PM
11's Avatar
I put a 00 si dash into my 92 hatch and had the same problem, the ground was loose, tightened it and it worked like new.
Old 04-24-2002, 01:14 AM
11's Avatar
Default Re: gsr dash into eg problems... (slickshoe)
unfortunately i sold it, i might have some stored in my comp. let me check and ill get back
Old 04-24-2002, 11:17 AM
yes...please check out my complete install guide found here
http://www.fifthgearonline.com/installs/gsrcluster.htm
Old 04-24-2002, 11:28 AM
thanks for all the help... ill go try it and if i run into any probs... ill post again... thanks again...
Old 04-24-2002, 12:00 PM
you can e-mail me to.....check the profile
Old 04-24-2002, 12:29 PM
p.g.'s Avatar
this is a question unrelated to the wiring, but has to do with the actual act of getting the dash into the car...
(i am under the assumption you have a fifth gen hatch.)
what type of fabrication did you have to do with the dash to get it into the car?
ie: what did you have to cut out, etc... since the dashes are completely different. also... did you have to do anything to compensate for the different sizes ... such as with door panels, etc.
thanks in advance if you have time to reply.
Old 04-24-2002, 01:40 PM
PatrickGSR94's Avatar
Default Re: gsr dash into eg problems... (p.g.)
look for WykidEG6 on this board, he's done it and can help you out (I was at his house when he was working on it, it works great).
Old 04-24-2002, 02:55 PM
Default Re: gsr dash into eg problems... (PatrickGSR94)
i tried him before never replied back...??? ... but basically everything bolts up... u just need to rewire and cut ur door panels...
Old 04-24-2002, 04:51 PM
p.g.'s Avatar
this is going to sound stupid, but the thing does not go in... and how much do you have to cut the door panels?
sorry if i'm a pain
Old 04-24-2002, 10:33 PM
everything fits... u just gotta play with it... and u have to cut about 1-2 inches off the door panel...
Old 04-24-2002, 10:43 PM
Mike B's Avatar
sorry if i'm a pain
1) The Clock on the GSR dash will have to be drilled SLIGHTLY 1-2" to the left of the original hole.
2) You DO NOT have to use the Integra side mounts all. That is bogus. You would just have to be creative and drill the plate mount to match up with the GSR dash.
3) It is not that simple to cross reference the wires into the "correct location." Keep in mind, you are using OBD1 harness + OBD2 Cluster.
I had it in my vehicle and the WHOLE under dash harness was necessary for the install. It was basically just plug and play with the exception of relocating 2 wires.
To make the heater valve work properly, I would recommend using the Integra Heater Valve.
Old 03-10-2003, 11:18 PM
Aaron.'s Avatar
anyone in Nor Cal did this before? pm me if you did. thanks.
Old 03-18-2003, 09:49 PM
Dancing is Forbidden's Avatar
Default Re: gsr dash into eg problems... (Zensokuryoku)
Im thinking about doing this swap someday.
Old 06-17-2004, 11:07 PM
blackshadow1978's Avatar
how did you get the dash in. wasn't the vent from inside in the way.
can you explain in details how you did it
Old 06-17-2004, 11:58 PM
str8cyko's Avatar
Default Re: gsr dash into eg problems... (blackshadow1978)
i would use an integra heater core so all the vents line up. i didn't have to drill new holes in the side mounts(i pushed the dash in while my cuz put in the bolts...took some time but it worked). i used all the teg wiring and both fuse boxes. hth.
Old 06-18-2004, 01:57 AM
a1320honda's Avatar
Default Re: gsr dash into eg problems... (cycocivic)
this cluster came out of a 00' auto teg. wiring was a snap and i have had no problems whatsoever. so whoever said that the obd2 cluster will need the underdash wiring harness is wrong. proof right here. you just have to do a little searching on here. sorry for the blurry pic
Quick Reply: gsr dash into eg problems...
