gsr brake booster and master cylinder how to install eg????
Well i want to install this stuff on my eg hatch but do i need a certain year or what else do i need for this thanks for the help
Re: gsr brake booster and master cylinder how to install eg???? (spencedogg)
If you use 94+ Integra RS master cylinder it will bolt right in without bending any brake lines. Gsr, LS, or GS you have to bend one line.
Re: gsr brake booster and master cylinder how to install eg???? (93LSivic)
Basically you remove the 4 nuts holding the booster to the firewall. The are located uner the dash and are quite difficult to get to. Use open ended wrenches if possible. Once those are removed, you must take out the cotter pin holding the brake 'pedal' to the booster. Then just remove the MC/Booster aseembly and lastly replace it with the integra one in reverse order.
This is are rudementary instructions but should get you started.
Re: gsr brake booster and master cylinder how to install eg???? (Charlie Moua)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Charlie Moua »</TD></TR><TR><TD CLASS="quote">does anyone know for sure if i can use a 94+ GSR brake booster and MC on my 95 civic EX? </TD></TR></TABLE>
Yes but you will have to bend your brake lines a bit because they won't match up with the fitting exactly. Plus I believe that the ABS fitting is bigger on the gsr so you will have to flare your existing fitting.
Re: gsr brake booster and master cylinder how to install eg???? (Kalokohan)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Kalokohan »</TD></TR><TR><TD CLASS="quote">
Yes but you will have to bend your brake lines a bit because they won't match up with the fitting exactly. Plus I believe that the ABS fitting is bigger on the gsr so you will have to flare your existing fitting.</TD></TR></TABLE>
thanks for the help guys.
yes the 95 civic 4door ex does have ABS.
so would i use the 94+ gsr brake booster and MC?..... bending lines is fine with me. do i need to upgrade my stock proporting valve?
so would i use the 94+ gsr brake booster and MC?.....</TD></TR></TABLE>
Yes, an integra mc will not bolt up to a civic booster....you need the combo to make it work.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote »</TD></TR><TR><TD CLASS="quote">do i need to upgrade my stock proporting valve?</TD></TR></TABLE>
not necessarily, i know people with rear disks who run stock prop valve....it's recommended because it helps distribute brake load.
https://honda-tech.com/zerothread?id=364783
If I could make a suggestion, take a look at this thread. I did this swap and love it, you'll save money and time.
Warning though. It makes your brake booster less effective, meaning you have to step on the brake harder. I like it though, because I have a more direct feel.
Re: (DaX)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DaX »</TD></TR><TR><TD CLASS="quote">
If you're changing the booster, be prepared to take out your intake manifold.</TD></TR></TABLE>
This is not necessary. I just swapped in a MC/Booster from a RS. It was a tight fit but I was able to get it out without removing the IM.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Charlie Moua »</TD></TR><TR><TD CLASS="quote">do i need to upgrade my stock proporting valve?</TD></TR></TABLE>
it's best to use the proportioning valve that goes with the MC.
Re: (wdskuk)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wdskuk »</TD></TR><TR><TD CLASS="quote">can I put a jdm type r MC and BB into my 97 hatch</TD></TR></TABLE>
Yup, thats what I have in my 96 hatch.
MistahJuice
Suspension & Brakes
05-10-2015 09:18 PM
spoon978
06-10-2008 07:34 PM
kajay1972
09-05-2007 07:16 PM
