Ground Problem
Ground Problem
heya, i posted a few weeks ago how i had a idle issue, couple of people mentioned it was a vacuum leak. Well fix that but the cra still idles. Then i noticed today, i flipped my lights on WHILE it was fluctuating and it seem to go to a perfect idle. Is that a ground issue i imagine? Am i probably missing a ground or something since there was a swap somewhat recently? thanks! ALSO if i do leave my lights on for awhile, the car will then again to idle funny
Re: Ground Problem
Was good i had the same problem where it would rev wierd as hell but you should check your throttle cable cause the boot could cover up where the cable is frayed or is comming loose change your throttle cable then you should be fine
Re: Ground Problem (SammyYankee)
hehe cable is good, i live in the engine bay haha, had so many problem with this car haha like little misc stuff that i don't know hwo to take care of haha
sleepyhamsterlx
01-06-2004 07:30 PM
