ground control ?
ground control ?
i got ground controls from a friend and i already have koni yellows, what does the gc/koni yellow combo have different. and can i put the sleeves right on the clamp on the shocks
Modified by gen 5 hatch at 6:12 AM 12/18/2003
I believe it has something to do with the perch. You can buy the special perches for $10 each from ground control to use with non-koni GC's paired with koni's.
Re: (EkREV)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EkREV »</TD></TR><TR><TD CLASS="quote">you'll need an koni adapter from ground control. call them up and order one and then your set...</TD></TR></TABLE>
yup, they are like $25 a corner.
Re: (whoDAT)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by whoDAT »</TD></TR><TR><TD CLASS="quote">
yup, they are like $25 a corner.</TD></TR></TABLE>
yep hes right comes out to 100 bucks, and its well worth it. The GC/Koni setup is THE BEST setup if your not going full coil over. the setup with this is endless.
New User
Re: (blackeg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by blackeg »</TD></TR><TR><TD CLASS="quote">do u need this adaptor to use gc's with agx's....</TD></TR></TABLE>
no...
no...
Re: (EkREV)
no...</TD></TR></TABLE>
thanks for the quick reply. sorry about the semi- hijack.
New User
Re: (gen 5 hatch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gen 5 hatch »</TD></TR><TR><TD CLASS="quote">so i def need this adapter. or can i set the sleeve on te perch that koni has
Modified by gen 5 hatch at 12:50 AM 12/19/2003</TD></TR></TABLE>
no...you definately need the koni adapter for it to fit.
