ground control???
ground control on stock 2000 civic si shocks??? pls help...
just wondering if you guys can help me out, i was wondering if ground control works good with my stock shocks??? i have 2000 civic si...pls reply
Modified by KOKEY04 at 9:33 PM 10/16/2007
Depends how far of a drop your planning. If your struts arent shot as it is, you shouldnt have any issues with lowering it up to about an inch, generally like eibach lowering springs would do. Anything lower than that, you should consider aftermarket struts. Just my $0.02
Re: (KOKEY04)
i'm with 97j6mike, minor dropping is okay with your stock shocks, but if it was me any kind of a drop i would just do a whole aftermarket spring and damper set-up. 2" is more then minor, so can you do it yes, but after awhile your shocks will go bad and need replacing anyway.
