Got scammed on ebay, can someone ID this Harness for me???
Re: (GS-Rcivic)
Its a dash harness.....I don't think that connects to the ECU...those connectors go to the fuse panel under the dash on the drivers side.....
check that out...
check that out...
Re: (PaChiLa Leader)
There is one harness that connects to the fuse panel and runs to the instrument panel and for other items, like stereo, climate controls and other things on the dash. That's the one you bought.
There is a seperate harness that runs from the ECU and runs along the firewall and connects to things like the sensors on the pedal assembly, lights, security system, relays, etc....
When you remove the dash out the car, the dash harness is what's connected to the dash. The one that connects to the ECU stays in the car and is located behind the dash.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PaChiLa Leader »</TD></TR><TR><TD CLASS="quote">
oh gee.. so i made the mistake buying a wrong part then.. i always thought there is only one harness thats behind the dash called "cabine harness and goes to ECU and all the stuff behind the dash~ </TD></TR></TABLE>
agree with marauder. i've bought a few harnesses and this one is for the gauge cluster, climate controls, and stereo. maybe some steering wheel controls too. there is one large harness for the rest of the dash like marauder said...the one you have is just a sub-harness for the stuff mentioned.
as far as the wrong part...maybe. maybe the guy didn't know what he was talkin about. sell it, and find out exactly what you need.
at the jetties fishin'
Re: (bluecivic05)
yeah, its definitely a 94-01 teg harness, those are most definitely integra gauge cluster plugs....the two light blue ones in the middle.
There are two different harnesses in the 94-01 tegs. The dash harness that comes out with the dash, and the firewall harness, that runs along the firewall and plugs into the dash harness...as well as the ecu harness, etc.
some people also call it the body harness but that confuses it with the one that runs along the door sill to the back of the car which is also called a body harness. lol.
Re: (EVILhatch)
its the right part, but what you thought was wrong.
94+ integra harness, connects to the driverside fusebox.
cruise, dimmer, cluster, radio, clock, cig lighter
yeah that's the dash harness. i think you'd have to ask for something like "complete engine wiring harness, w/ECU hookups?" i could be wrong but that sounds more like what you're looking for, not just the wires for the gauges and stuff.
TranceAddicts
04-26-2011 09:04 AM
