got new pads/rotors, need brake fluid?
I just got new pads/rotors. Do I need to change the brake fluid as well during the install or could I just keep the same oem stuff? Thank you.
Re: got new pads/rotors, need brake fluid? (wilsel)
I changed mine recently... no need to change fluid, just make sure that you pump the brake pedal after you release the calliper clips to ensure that the fluid gets all the way into the system.
If anything, you will have a higher level of fluid in your resevoir due to the thicker NEW pads replacing your old worn THIN pads
But as Slow said... replace over 50k miles...
Re: got new pads/rotors, need brake fluid? (Slow_Em1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Slow_Em1 »</TD></TR><TR><TD CLASS="quote">yes make sure to get DOT4 or up, nothing less </TD></TR></TABLE>
incorrect. dont use DOT 5
Former Moderator
Re: got new pads/rotors, need brake fluid? (jonas)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jonas »</TD></TR><TR><TD CLASS="quote">
incorrect. dont use DOT 5</TD></TR></TABLE>
Exactly.
DOT 5 sucks ***** for cars because it requires much more bleeding and more frequent bleeding.
Also you don't even have to disconnect the brake hosrs on the calipers to do front pads and rotors - no need to buy fluid.
Exactly.
itr1244
05-17-2004 01:31 PM
