Good White HeadLights Bulbs
Re: Good White HeadLights Bulbs (DipsetCivicEx)
PIAA is a very good (and expensive) maker of light bulbs. They are nice and bright. You mentioned white in your title so I am assuming you do not want the blue look so then you would need to research and find a chart that tells you about color temperature. Basically the degrees Kelvin of a light is the color it will be. Something around 4000 K looks to be pretty white according to this chart and info.
http://www.piaa.com/Bulbs/BulbsAbout.html
Here is a little more about color temperatures
http://www.tvtechnology.com/fe...shtml
Hope this helps
Hope this helps
Imperious: Mod of Valor
Re: Good White HeadLights Bulbs (boostedcivicsir)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boostedcivicsir »</TD></TR><TR><TD CLASS="quote">raybrig only bulbs i use.</TD></TR></TABLE>
True, but these are expensive as hell.
